Where to start?
Damien
TN
I have not done any performance related mods to my Tahoe yet but I have a few planned. I wanted to get some guidance on which order I should do them in, maybe some brand/product suggestions, or anything else to add to the list.
Vehicle: 04 Tahoe LS w/ 4.8, 93k miles
My goal is to get a little more power without sacrificing MPG, maybe even gain some MPG. Most of my driving is on the interstate with lots of hills and it likes to downshift for long periods of time. I've also got a lot of weight in the back due to my sound system (400 pounds or so, will be closer to 700-900 soon) and a dual alternator setup (stock 130a + 370a hairpin from Mechman).
So far, I've planned out these upgrades:
Tune: I've heard good things about the BBP tunes. HP seemed to be decent as well.
Intake: After doing a price and performance comparison, a volant intake with a dry filter is most likely what I'll use
Electric Water pump: Haven't looked into this yet but I've seen it referenced quite a bit.
Electric AC: Didn't find much about this yet but saw it referenced once or twice. Same as above
Exhaust: Another I haven't really looked at. Not really looking for loud, just something with a nice sounding deep tone and/or performance gains without breaking the bank. I do have to go through emissions though.
Cam: I'm not sure if I'm comfortable messing with the internals of the engine myself so I'd most likely have a pro do this part. As such it would probably be the last and most expensive part.
Another not so performance related mod is that I'd like to add some sort of switch to up my idle if possible so that I can rev up the engine to get the alternator output to its maximum level without manually pushing the pedal. I wouldn't want it revved up all the time at idle, just at audio shows/competitions.
ezdaar
Chat Troll
Redneck central, Aka Houston
Agree with Jenna, but with a minor shuffle.
With Blower,
Stage 1: gears, efans, stall, transmission,Catback, tune
Stage 2: blower, cam, headers
Stage 3: E85 upgrade, Nitrous Or Methanol kit, Crank up the boost.
No blower,
Stage 1: gears, efans, stall, transmission, Catback, Modified Specter intake, tune
Stage 2: NNBS Intake manifold, cam, headers
Stage 3: Nitrous soft hit Progressive 250 shot.
Damien
Damien
TN
Not really looking to swap the gears as most of my driving is on the interstate. I'll probably stick to stage 1 or 2 on either of your lists
ezdaar
Chat Troll
Then you need to X all the above and just bolt on a blower. It will give you everything you are looking for and more.
Skip, headers, cam, cai, all that shit. Bolt on a tvs1900 and a good tune.
Thats the iconic example of a happy pig!
No mpre down shifting while cruising, no more searching for power! Just a pure honest good beast under your foot! The more it whines the more it loves you!
You need a blower. Frack all the other candy.
DPGDirk
No blower,
Thought about posting separately, but this is probably beneficial for all right here.
What gear ratio would work and still allow for some good highway driving? Mine also downshifts a lot- especially when towing the polaris. (Only a few times a year)
I don't know what gear ratio comes stock....?
Is the rear axle in the 1500 the same one in the 2500? (just wondering about strength)
I have heard about the NNBS intake swap. Is the throttle body different as well, or do you use the same one?
Is there more than one model out there, or are they the same?
What kind of gains are we talking about?
Looks like you can buy aftermarket intake manifolds really cheap...?
I read on recommended forums and all I mostly hear is abbreviated terms amongst the already indoctrinated, which is mostly code speak to me and I can't find specific answers, part #'s, etc, and often just give up with my eye's bleeding.
I'm gears and E-Fans away from finishing step 1. Already have the headers and exhaust waiting to go on for step 2.
My biggest quandry is whether I'm really going to want to pop for the cam or if I can live with everything else and a good tune. I do want to retain some reliability and driveability.
Not looking to add 100RWHP, but some smaller portion of that and being able to DD would be great.
Thanks!!!
4WDTRK
sleeps in garage
Socal dreaming of Norcal
What's the ball park ($$$) on that blower setup?
Damien
Damien
TN
Sounds expensive
ezdaar
Chat Troll
Used or new for blower?
Ive seen complete decent mileage TVS1900's as low as 2500, but thats Rare. most the time 3-3500, with out fuel pump.
If you get post count up on performancetrucks.net and post a WTB. You will be Flooded with offers.
For the power to $ gains, its the cheapest way to go. upwards (on a stock pulley) of over 100hp is very easy to achieve.
@JennaBear for new price.
gears,
Even going from a 3:23 to a 4:56 you will only see a raise in cruise RPM by 500Rpm or so.
You want some pop off the line and towability (is that a real word? lol) with big tire, fat pig. 4:1X or bigger.
Rearend,
They are different. 2500 has bigger stronger rear end and 99% of the time has a 4:10 or 11 in it. I always get them confused. kinda weetarded like that.
NNBS intake,
Yes the throttle body is a 4 bolt and bigger vs the NBS 3 bolt.
There are a few manufactures that make a adpater plate to use your 3 bolt TB on the NNBS intake, if needed.
Typical gains are aprox 15-25HP, this comes down to many factors. Tune, headers, etc.
Its worth it! no other mod to your engine next to a cam gives as much power to $.
I have seen them sell complete with Throttle body and injectors as cheap as 150$, but usually average 200-250. If your patient. you can get one complete with Flex fuel injectors for 250.
You will want the FF injectors, as soon as you do the intake and headers. you will max out your stock injectors. The FF injectors gives you plenty of headroom on your IDC (injector duty cycle), as not to max them out.
Cam,
HELL YEA you want one! easy 35-100HP gain with a cam swap!
Obviously the more power gained = the more radical it is and more supporting mods it needs. This brings us to converters. the bigger the cam, the bigger the converter number.
Your stock is aprox 1800, a typical daily driven, small cam wants a 2600-3k.
But you Can get away with the oem convertor with the right cam.
Combine these parts with even a small cam and you drastically change the power profile of your ride. it goes from boring, even with a good aggressive tune, to a HOly shit this is Nice! This is how GM should have made these vehicles from the start!
Damien
Damien
TN
Question on the NNBS intake - how does it compare performance wise to aftermarket intakes made for the NBS (volant and airraid are the 2 I looked at)
Damien
Damien
TN
Maybe my goal of eventually hauling the 10-12,000 pound ambulance loaded down with audio equipment isn't so far fetched with the right upgrades...
ezdaar
Chat Troll
When i say "NNBS Intake" i mean the intake manifold, the big ass black chunk of plastic on top of the engine.
Not the intake tube, as in a volant, k&n, etc. thats a CAI or cold air intake system.
#1taho
5150TAHO
niagara falls ont
I am curious on the nnbs intake. PLEASE more info. Will the throttle body work with out any trouble? whats involved in this swap????
Damien
Damien
TN
What I really want to do is swap to an LBZ... but that's a lot more expensive than it's worth
Candielaine
