Fog Light LED?
byrds6
FL
Are the LED bulbs for the fogs a direct plug n play or is there something else you have to do to use them? Also, if they are plug and play, what color is recommended? Right now I just have Silverstars in the headlights so they are super white or anything.
byrds6
byrds6
FL
Anything in general recommended? Would like a bit brighter than the stock bulbs but not super white since it wouldnt near match the headlights.
01Konvict
Boats n Hoes
Raleigh/SML
What kind of real life light output is there from these? Did you get the 5202 bulb set or modify a H16 set base to fit? Thanks for the information....
I got a lot of output from these lights! Because they have one led on each side they light up really good. I will take some pics of them to post the difference but can say they are well worth the money. I got the 5202 bases and one for perfect the other was a pain. Ended up holding one of the two clips down with silicone on the fog light outside. No big deal just the clip didn't really hold it in. Also had to shave part of the plastic bumper on the inside so the square fan heat sink could fit. But would buy them again for the light output
felixgun
Lafayette, LA
Derek I've had a set of this, they're OK, but literally 1/10th of the output of the one Wade has. It has a separate ballast to power them up, so they're so bright. I've had both similar sets, and definitely go with ones that have a ballast.
Mester320
Fort Myers, FL
Just got these in last night. They are 5202 5000K VLED fog bulbs. I have 5k HIDs and 5K switchbacks and they are a perfect match.
Stock on left, 5k VLEDs on right
Both
Beam patterns (only fogs and switchbacks are turned on)
Mester320
Fort Myers, FL
If you are talking about the VLEDs then yes no issues. That is what you see in the pics. I didn't even take off the bumper to install just unscrewed the fender wells and reached in
carduke
Nice choice. Vleds has quality LED bulbs. I bought interior LED bulbs from them before.
Kcrowe79
