Pioneer 4100NEX installed
Bruizza
I replied in your other thread about having the 4000nex. I use the apple carplay and it works fantastic. I am not having the issue VTHokie is with my reverse camera. Mine always works. Supposedly the main difference between the 4000 and the 4100 is the 4100 supports android. Might be worth looking into. I snagged my 4000NEX for $350. Might save you some $
DjJayFrree
DJ to the Stars
East Bay Area RI
$350 is a STEAL! looks like $440-500 on ebay currently!
---------- Post added at 10:30 AM ---------- Previous post was at 08:51 AM ----------
Aurum Ultra Series - High Speed HDMI Extension Cable Male - Female (3 Ft) with Ethernet - Supports 3D & Audio Return Channel [Latest Version] - 3 Feet https://www.amazon.com/dp/B0069A6K6I/ref=cm_sw_r_awd_EvzWvbDEY0X3Z I used this to extend my hdmi under the center console. Haven't plugged anything into it, still figuring out what to use the hdmi-in for
Metra GMOS-LAN-012 06-up GM Onstar Rentention Module https://www.amazon.com/dp/B005F4ISJQ/ref=cm_sw_r_awd_rwzWvbASQ0H3X
MXtechnic 3 Feet 1 Meter Dual USB Male to Female Extension Panel Flush Mount Cable For Car, Boat and Motorcycle https://www.amazon.com/dp/B00XL09YLW/ref=cm_sw_r_awd_5wzWvbHDA67E4 I replaced the left cigarette lighter with this. Fit pretty well and without much issue
5 pc. No-Scratch Tools for Removing Fastener & Molding https://www.amazon.com/dp/B000LNBLTK/ref=cm_sw_r_awd_FxzWvb3M9EPD4 Made things easier & no scratches
Metra 95-3305 Double DIN Installation Dash Kit for 2006-up Chevrolet Vehicles https://www.amazon.com/dp/B000K52CWO/ref=cm_sw_r_awd_4xzWvbV90GE65
Metra Axxess ASWC-1 Universal Steering Wheel Control Interface https://www.amazon.com/dp/B00B4PJC9K/ref=cm_sw_r_awd_tyzWvbPCGVG7J works mostly well, might would consider a more customizable one if doing it over
MicroBypass Parking Brake Switch Fully Automatic Video in Motion Interface for Pioneer Model AVH-4100NEX https://www.amazon.com/dp/B00VKQ6ECQ/ref=cm_sw_r_awd_UyzWvb1FJF2J1
Clarion Corporation of America CC510 Compact Automotive Color Camera with Distance Markers for CAU001 https://www.amazon.com/dp/B00B43LK7E/ref=cm_sw_r_awd_pzzWvbSCYRQ18 works well, grainy at night as they all are
Sent from my SM-N900V using Tapatalk
don't you need an antenna adaptor as well?
vt_hokie2008
vt_hokie2008
VA
The Metra GMOS-LAN-012 came with one (naturally after I had already ordered one).
vt_hokie2008
vt_hokie2008
VA
Probably not, I've never used it and never plan to
DWebPro
Stevenson Ranch, CA
I thought the rear seat video hadn't been figured out yet using the oem pull down screen, did I read that incorrect somewhere?
vt_hokie2008
vt_hokie2008
VA
To hook up to my headrest monitors (dealer option) I have to run RCA to the front of the screens. There's no hookup on the control box or anything. With a factory ceiling model, I'm not sure. Ask Crutchfield if it can be done, they're useful for info like that.
Bruizza
I know my 4000NEX has the RSE option which mine currenlty says is not enabled but I don't have RSE. I was just going off that.
Blakefamily
Planning to put one in? I can give you a parts list and everything for it. If you have Bose, which type of amp you have will determine how it has to be wired.
We have an 08 tahoe Z71 with boss without nav. How do I know which amp I have ? Thinking we wired incorrectly because we have no sound coming from the rear speakers :(
vt_hokie2008
vt_hokie2008
VA
I had nothing from the rear & had to use the additional harness for the rear speakers (green & purple wires i think)
jebt2921
AR
I too had to cut out the plastic to get my setup to work in my '08 hybrid tahoe. I've got the same harness using a pioneer 8500bhs and my rear speakers have always been strange. One barely has sound out of it and if I press the power source on the 2nd row console the opposite 2nd row speaker turns on really loud. Then after 30 secs or so something in the rear makes a loud screeching noise for a few seconds then repeats every minute or so. I've landed on just mainly relying on the front speakers. Pretty strange. Steering, mirroring to head unit, 2nd row ceiling monitor (using dvd only) all work fine. May have wired the rear speakers incorrectly but am usually very careful and triple check things.
Let me know if you have any thoughts.
vt_hokie2008
vt_hokie2008
VA
I ended up calling Metra and talking to their support people to get mine working. They were pretty good and knew what code to look for to know which amp I had to determine how to wire it. Works perfectly after that phone call.
vt_hokie2008
vt_hokie2008
VA
If you have an 08 you have an analog amp. Metra told me only the Denali had a digital amp until 2012 or something like that, then the LTZ got it
Blakefamily
Thank You. Also curious with your dual USB port you installed in the outlet, did you hook up both in the back of the stereo? Isn't one for Ipod? Is there a use for both? Can you charge with both?
vt_hokie2008
vt_hokie2008
VA
They're both hooked in to the back of the stereo & both can charge. You have to pick android auto OR apple carplay in the settings, so mine is on Android Auto all the time with ny phone running that while my wife's iPhone is plugged into the other port just to charge. On the back of the headunit, one port is for Android & one is for Apple, so you gotta keep up with which is which. My phone will actually charge while navigating & playing music, but not at wall charger speeds
Drewphil
