Put up your speaker box pix and custom install pix up!
OmarR
Indianapolis, IN
Did you install it yourself? I am a n00b and I would like to install it myself if it has instructions available.
I did the install myself.
It did come with instructions, but you have to be comfortable with running wires under panels and soldering wires onto the subwoofer outputs at the stock amp.
gmcjohn
I have mine tucked away because I have to haul stuff in the back every now and then...
Custom car stereo in Houston did the work. It's a JL W1 10" in a sealed box powered by a 250 watt PPI amp (IIRC), soon to be a PPI PCX280, with the sub amp being used to power the front components. And the amp is bolted down, it is not loose in there. It is unbolted in the picture b/c I was working on it. Sounds great, just loud enough without being obnoxious, but it bumps if you want it to.
And the sub and amp have both survived my car getting broken into twice, if I had it sitting in the cargo area with the amp stashed under a seat, it would be long gone.
How much did that cost you?
dblover1327
Denver
Mine isn't done yet but its consiting of 2 sundown 3000, 2 ia dp 18, 100.4, 50.4, 2 tyco elect batts, 4 6 1/2 eton lpg mids, 2 xt25 tweets, 2 d26 vifa tweets. So far got everything in just the subs
take more pics tomorrow
thehoe92
fo sho
The916
thehoe92,
That is absolutely ridiculous, are your ears ok?
my ears are fine... for now I know everyone says that I will be deaf but as of right now having a mid 40's system for a year I have only noticed a tiny bit of hearing loss but for the most part I can hear fine.
I am planning on running 2 18's next on close to 8,000 watts or 4 15's on the same power.
a t-line is a transimission line 1/4 wave lenth.
it is supposed to be the perfect environment for a sub with total control over the cone and in theory you only need about half the RMS
tx tahoe z71
Houston, TX
You can probably build the setup yourself with some MDF and some power tools for pretty cheap. The sub goes for about $110, and you can pick up good amps on ebay for cheap (make sure it's a reputable seller though so you don't get a dead amp).
I bought it from a friend for $250 for everything, but I believe he paid close to $1,000 for it installed in his tahoe with sub, amp and wiring.
Young28
The Yukon God
ga
Pure sex of an amp.
NoPh33rRaCiNg
Kent, WA
Pioneer DEH-P8MP (for now) 6v preouts :manos:
Powermater Polished 240 Amp Alternator, Beefed up by Mechman. Does 138 amps at idle
diffrnt
Say...What!
MS
I had this in another post but here is mine. I’ve had it for a little while now and I like it.
Clarion 575USB
Factory LCD
Clarion EQ
Kicker KX350.4
Kicker KX750.1
Kicker S15L5
DTV Converter Box
Inverter (powers the DTV box)
Deka Intimidator Battery
blueflamed03
Oklahoma
my buddy did this install for a friend of a friend. Daily driver.
MikeTheApeman
The armpit of America - New Joisey
Will this work with a 2000 Chevrolet Tahoe?
If the part number is the same, yes, it will. I can't remember if 2000 was a different box or not.
I have the same box as Omar, but I used the MTX-supplied grille. I'll snap a picture tonight before the snow gets here. Personally, I think the MTX Grille doesn't look bad at all, I was 1) too cheap to buy a panel with the grille and 2) too lazy to dremel out all the little slots by hand.
cjsacm1
Killeen, Texas
here is a picture of mine, all custom just not good looking custom
X-ray Nerd
