2002 Yukon, 140k miles, Fixing up over time
T
tgui
Some water in the pan after a TON of cleaning. Otherwise everything looks nice I think? This is the first ever trans pan I've dropped. From what I read the color is good, not burned smelling and not a ton of debris in the oil and nothing major on the magnet. 15k-30k miles on this trans from a HD truck with a 454.
Thoughts?
This is how I did it without a proper stand. I of course made a mess but I really really wanted to see everything that came out without disturbing the pan too much.
T
tgui
Got some ebay parts.
Trans dust cover cheap, needs cleaning.
Front driveshaft from a HD truck. This is long enough.
4x4 end thingie for the trans. (transfer case adapter) Now I need a shorter 4x4 output shaft.
Baby steps...
T
tgui
Got a trans cross member for $20, need to clean, cut and mount for the trans.
T
tgui
Tear down. Found the wiring harness main connector to be damaged, I'll replace the whole harness just in case. Everything else is looking good.
Random pics, not terribly interesting:
Big picture pic to help remember where things go.
To get the valve switch (I think its called) don't yank as o-rings might come off or get damaged. Twist and rotate down and it comes off.
Check balls out and inspected. Look OK. Dinner time...
T
tgui
Took pump out and some stuff fell out.
---------- Post added at 01:19 AM ---------- Previous post was at 01:18 AM ----------
T
tgui
Still going slow on the trans. I did get my hands on the dust cover. It appears the flexplate exploded. No joke. Edged are chipped off and the housing is a tad cracked. Nothing to stop it from working though. Anywho I was able to clean it up nicely.
T
tgui
Got a 32 spline input shaft for my np246 transfer case. This is needed to join up the trans output shaft. Part number 19019
T
tgui
I need to just document stock trans cooler lines that would fit a newer style 4l80e. Mines the older style, but can't hurt to know this.
15812029
15267484
T
tgui
More precisely wifey and I adopted this beast. We're slowly getting her to get along with my manx. Not truck related, but hey, I like animals. This is taking my time. ;)
1st cat
pwtr02ss
Tennessee
Fine looking cat. I have a black cat that looks like that. Also, do you have the DVD for rebuilding the 4L60 transmissions? I bought it when I bought the manual. Very nice. Used it while rebuilding on in a SSS, never even touched the manual. Pm me if you don't have it.
Edit: never mind, you're build a 4l80...Reading fails me sometimes
T
tgui
You might find a torrent for the 4l60 DVDs ;)
No updates really here. I've been using the truck too much. Plus the garage has been very cold. Oh, and I'm amazed at how well auto-4x4 mode works. Also, rag on the G80 gov bomb diff, but when used right it works DAMNED well!!!
TheAutumnWind
I really appreciate this thread! It wqas fun reading through. Keep up the good work sir.
I've been watching these lately.
http://www.transmissionbench.com/index.html
https://www.youtube.com/channel/UCXqufnwB1bb0QKnP2Owo3nA
T
tgui
I did a little cleanup and fixed a couple things. No time for the trans yet.
- Detail & polish
- New wipers
- New mirror switch, the one I thought I fixed started breaking again.
- New lower lights/bulbs
- Finished blacking out the front
- ... and so forth
She looks good about 2 feet away ;)
Buford bubba
