suspension lower on left side???
08mericxldenali
hello guys, I just noticed and don't know if it is normal or not but my 08 denali looks lower on the rear drivers side. Is it normal? ive checked pages stating it is due to the gas tank being on that side but I don't see that on some denalis ive seen on the streets. Measured and it is close to 3/4-1" difference between sides. I also checked suspension components and all looks normal to me. Don't think it is air ride related since the height of the truck is set by the springs am I right? Any help is appreciated!
GMT800 2005 Tahoe Z71
Navy Supporting Member
The air ride senses when there is added weight at the rear and pumps up to maintain ride height and ride quality. Does not sound like the left rear shock is working properly or you do have a spring problem, maybe. Is the front even?
08grey
It's normal unless it's more than a half inch. It's annoying and you can fix it with some added rubber spring seats or a spacer. But even that is hit or miss. Yes some don't seem to have it and I bet there are times when your truck sits perfectly level also just can't notice it because your in it. I think we all have experienced it. Look up Cali lean or Chevy lean I forget which but you will see a lot of posts.
Fat girl on the passenger side fixes it also.
NORCAL SS
SUV SUSPENSION GURU
normal. I have a trick to bring the pass side rear down to match driver side rear which in turn also lifts left front up a little PM me
So that is normal? That's just wrong. If is the norm then there should be a fool proof way to fix so doesn't stay normal.
I'm not saying it doesn't happen. I have heard of it but his amount seems excessive. Should be a fix that is easy. IMO.
08mericxldenali
The front is even. it doesn't matter if its running or not and the drivers side in the back is lower.
---------- Post added at 03:07 PM ---------- Previous post was at 03:05 PM ----------
Yes its pretty annoying. ill check those post for more info thanks
---------- Post added at 03:09 PM ---------- Previous post was at 03:07 PM ----------
PM sent
livingez_123
Sandy, OR
My 08 Denali is exactly ½" higher on the passenger side. I even measured it at the frame and it's still ½" so it's suspension related and not body mounts. The front is an easy fix, just take another ring off the strut but the rear is going to be different.
NORCAL SS
SUV SUSPENSION GURU
Correct pr another option to use 1 inch spacer deivers side it will level rear. Done it thousands of times for customers since 2000 when Ii sstarted dropping the 00 new models
livingez_123
Sandy, OR
I pulled one ring from the passenger side front strut and it went down ½" but the drivers side dropped also. Put the ring back in with new front springs and I'm back to ½" higher on the passenger side. So I jacked up the left rear until the back end was level. I put a ½" spacer under the spring and the rear was closer but still about ¼" off. This also dropped the passenger front a bit. I still think the front sway bar has too much pre load, I can tighten it down and watch the front left go down. It's frustrating.
Charlie21ny
