Magnaflow mufflers
tx tahoe z71
Houston, TX
I got the big body Magnaflow, 22" long, sounds like stock until I get on it, still pretty quiet though.
NJ04HOE
Paterson, NJ
I have a Magnaflow on my 04 and I love it! Just like TX Tahoe said it pretty much sounds stock until you get on it and that's exactly what I wanted. I didn't want to get tired of hearing a flowmaster or something like that constantly.
This is the one I have, is this the one you're talking about??
haks310
Got LEDs?
SoCal
That's is the same size I will be running, 14".
3" SI, 2.5" DO though.
Like, NJO nd TX said the 22" sounds like stock until you get on it, I am hoping the 14" will be noticeable at idle and yet not be annoying. Should be a really loud deep tone once you get on it.
"350Vortec"
*Tahoeless, For now*
Can you flip that muffle around and use it as dual in and single out? Im just looking for the easiest thing for my muffler shop to weld on so it will cost less.
jmildoc
Indianapolis,Area
I have a magnaflow on mine as well and I love the way it sounds, also gave me about 1.4 mpg increase!!!!
"350Vortec"
If you do get a new one 992door, i will take your 50 series off your hands.
haks310
Got LEDs?
SoCal
With Magnaflows you can, don't know about the Flowmasters.
Magnaflows flow more than Flowmasters do, but both flow more than stock so it just depends on what type of sound you are after.
992door
992door
Greenville, NC
Yes magnaflow is reversible.
I have also thought about getting a y-pipe put on and then a dynomax bullet and dump it just past the rear axle
blackcoffee
O.G. Black.
Do the y pipe mod so if you ever want to lift it you don't have to worry about it. Plus its cool.
992door
992door
Greenville, NC
i would still have to modify the exhaust if i lift it
---------- Post added at 01:07 AM ---------- Previous post was at 12:04 AM ----------
The more that i look the more that i change my mind. Now i am thinking that 1 dynomax race bullet will be to way to loud. I am looking something louder that the flowmaster 50 series but not obnoxious(sp?). So I am looking at the magnaflow 4x9 with the 11" long case and 17 overall SI/SO and putting a y-pipe before it to get it down to 1 exhaust pipe.
tx tahoe z71
Houston, TX
whats wrong with the flowmaster?
Flowmaster is made out of aluminized steel and magnaflow out of stainless steel, so longevity comes into play. Also Flowmasters are widely believed not to flow as well as a straight through muffler, but probably not very noticeable unless you have some big cubes or a power adder in front of it.
Rollin Thunder
Banned for Repeatedly Insulting Members
Va Beach Va
I meant why did 992door want to get rid of his flowmaster. I have them on mine and am quite happy to have the back pressure as I feel it got even more power out of it.
Rollin Thunder
Va Beach Va
spend it on somthing you dont have then if you want to differ your truck. Corsa is the only upgrade you should do to your exhaust from a flowmaster.
tx tahoe z71
Houston, TX
I wouldn't do the Corsa Sport if you plan on doing longtubes in the future, everyone says it sounds really loud and raspy afterwards. Go with the Touring, if you go that route
vsaravia
