Window squeak
denalianyone
NYBlackLade08
New York
Need suggestions on a good trick to stop the window squeak/squeal when rolling up and down the driver window. I don't want to remove the entire door to grease the rails. Is there a simple solution I can do to the felts that contact the window? I was thinking a q tip with some vinegar and water.
08grey
Is your door panel on correctly. If it isn't it causes a squeal make sure it's sitting in the groove of the rubber seal that sits on the inside of the door.
If it is and it still squeaks use sil glide on the metal tracks clean them with a wet rag with some degreaser first. This will last a couple of seasons.
denalianyone
denalianyone
NYBlackLade08
New York
how about WD40, spray on exposed window channel and roll up and down, repeat as required.
I'll look into doing this.
---------- Post added at 10:06 AM ---------- Previous post was at 10:05 AM ----------
I'll check but pretty sure it is.
jcgilli
Kansas City
Same here
Had the same problem here. The squeak is louder the colder it is out. Did 80grey's suggestions and all seems to be fine now. Thanks!
ScubaJim
funny mine was squeaking too but I thought it was the rubber and the cold temperatures....
JesseJ21
Same here
Just bought my truck and it has that same squeal. Please let me know if anyone has a picture of what they did to fix it.
briannorris
