My 04 Z71 LQ9 4L65E Build Thread
TxDrewski
Potomac,MT
As some of you know I purchased an 05 Escalade Engine and Trans from a member. It should arrive today or Monday, Ill get pics of it when it arrives.
Engine & Trans cost shipped:
$2300
First step is :
Melling Standard Volume, High Pressure Oil Pump 10295
$115.00
JP Performance Single Roller Billet Gear Set for LS1/LS2 Single Pole JP5622T
$84.99
BTR Truck Cam Kit With Springs and Your Choice of Camshaft (Choose Your Camshaft: BTR Truck Stage I)
$419.99
Delphi LS7 Lifters X12499225
$99.00
5/16 Chromoly Hardened Pushrods
$95.00
Cam specs are 206/212 .525/.534 114+2
Spring Specs are .560" Lift LS6 Beehive Spings
EDIT :Step 2 is a port and polish from Mike Stark @ CFM. Full job including re assembly and valve job.
400.00 + shipping
I will likely be using Chucks LSX tuning in Houston to do the swap, install the components and do the head work, with a dyno tune. It will save me time and $$ in the long run.
I will post pics when I can and post the current engine/trans for sale here and locally.
Stay Tuned TYF!
TxDrewski
TxDrewski
Potomac,MT
Look what came while I was at work!
Brain Tooley Racing is the place to go!
TxDrewski
TxDrewski
Potomac,MT
More stuff
Heres some more!
SunlitComet
OBS Jedi-Do Good
unknown at this time.
High pressure/volume pumps on an engine such as a street factory engine not built for track racing can cause so much pressure that the bypass valve will do it job so much that it can heat up the oil and likely cause aeration of the oil. Neither of those is a good thing.
TxDrewski
TxDrewski
Potomac,MT
Ahh okay. I had assumed that with a catch can and larger oil cooler I may need more than normal amounts of pressure I'll contact BTR, thanks Sunlit.
redemn93
Jupiter, Fl
you're really better off with a stock or ported LS6 pump. its all you'll ever need for that setup.
bottomline2000
Dallas, TX
I figured Sunlit would say it best. I'm looking at BTR dual springs with titanium caps., they seem to have good feedback on pt.net.
Sent from my SAMSUNG-SM-G900A using Tapatalk
TxDrewski
TxDrewski
Potomac,MT
Motor and Trans!
Well got the motor/trans. Had some issues in the yard lol. We just purchased an 07 Avalanche, had to run it 4low hooked to the trailer and the Hoe to pull it all out. Next step : Tearing down the motor.
TxDrewski
TxDrewski
Potomac,MT
Installed Headlights and Bulbs while waiting for the ground to dry up.
Z-56 Hoe
What do I do????
Houston
Stay away from Chuck, He is NO Good!!! Hell PM Tahoewhat also he will tell you the same thing. I have friends who had him work on their vehicles and stuff was not right at all. Do some google searches On him and on reviews. And look at his FB post on his customers. I bought some stuff from him. And he was way over priced but I was in a pinch and could not wait! I.E. Was home on leave from military. If you look on the Houston Craig's list he takes most of the page! There are way better people out there! KP racing , SHP performance, Fast Lane, Secret services , 510 Race engineering
TxDrewski
TxDrewski
Potomac,MT
Stay away from Chuck, He is NO Good!!! Hell PM Tahoewhat also he will till you the same. Do some google searches. On him and on reviews. And look at his FB post on his customers. I bought some stuff from him. And he was way over priced but I was in a pinch and could not wait! I.E. Was home on leave from military. If you look on the Houston Craig's list he takes most of the page! There are way better people out there! KP racing , SHP performance, Fast Lane, Secret services , 510 Race engineering
Well Shit Balls!!
Ill do some more research. I dont really have the time to pull the engine apart and install everything I purchased. Work has really picked up (amazingly). They were going to charge 1600 to:
Pull the 5.3 from the hoe
Install everything in the LQ9 & Do the head work
Install the LQ9
Dyno Tune.
All for 1600. Not too shabby for all that.
Z-56 Hoe
What do I do????
Houston
TxDrewski
TxDrewski
Potomac,MT
My last personal dealing with him was 08 or 09. It looks as tho he may have gotten better I'd still PM Tahoewhat tho!
http://www.ls1gto.com/forums/showthread.php?t=449561
http://www.camaro5.com/forums/showthread.php?t=258505
Also look at 510 race engineering
The search continues....
Thanks man. Im gonna call 510 tomorrow. i was gonna go through the guy we talked about doing the head work, but Id have to send him the heads and then take the motor somewhere else, then have BlackBear tune it etc etc. Because work has gotten so busy, I want ONE shop to do the work AND the tune. Charlie doesnt have time to pull and install the motor or Id be going that route.
bottomline2000
Dallas, TX
Price seems to good to be true. P&p and tune would eat up half the budget..i was quoted $2k just to r&r my motor...or my quote was high..
Ossipeelake
