Newbie 05 Yukon Denali
Rolex John
Greetings!
I'm considering the purchase of an 05 Yukon XL Denali with 146,000 miles. It will be a third vehicle for us, and likely will only see about 5k a year in mileage.
I plan to have a GM dealership service department go over the vehicle, but I'm concerned with the mileage, and have a few questions:
-Assuming proper maintenance, what kind of reasonable life expectancy can be we assume for the engine and transmission?
-What is the typical cost of transmission replacement on this vehicle?
-What kind a maintenance issues are common with this model and mileage?
Many thanks in advance for your time and expertise in responding.
JochenWoern
Sacramento, CA
Greetings!
Here some answers for you simply based on my opinions/experience:
My '04 YUKON has 143k on the clock and runs like a champ.
In my opinion, with proper maintenance these engines should go easily above 200k PLUS miles.
Can not help you with the cost of transmission replacement, as I am still running the original tranny with no issues.
I would say that common issues on our trucks are water pump and fuel pump, I read a lot about the auto ride compressors (which the DENALI has) failing.
I am sure others will chime in as well, but this is what I can offer. Other than belts and the oil cooler lines leaking, I had no troubles with mine so far and it has been a great truck.
Good luck and keep us posted, pictures are always welcome.
I personally would not hesitate to purchase this truck with those miles, as long as it is clean and well taken care off.
CKendrick
