2/3 vs 2/4 drop?
Bass911
I'm sitting at 34 1/8" in the front and 36 1/8" in the back on factory 16s. I'm assuming it would be better to do a 2/3 drop on 26s because I think the back would sit lower than the front with a 2/4 drop? Is this correct?
Bruizza
It would be damn close to lower if not lower. I dropped mine 2/3 on 26s and it is damn near level. I would think an extra inch in the rear would make the rear sit lower.
robstor
Yeah but I depends on the torsion bars. You can make the difference up with a little adjusting of the torsion keys.
Sent from my Lumia 710 using Tapatalk
NORCAL SS
SUV SUSPENSION GURU
This depends on what spings gm used in rear (some sit lower /higher) In front can vary where the torsion keys are put.
If you do 26s i would do the 295 30 26 and this drop kit
http://www.tbssowners.com/store/index.php?act=viewProd&productId=86
295 30 26
26x10 with 30mm offset
Any questions just ask.
Tony
B
Bass911
Eickybobby5050
