BOSS's Hoe
BOSS
The People's A D M I N
Dallas
(edit) I'm NO LONGER going through TF.com withdrawals
BOSS
BOSS
Dallas
Yo!
She's many pounds heavier that's for sure! Dynamat'd the hood, firewall in the engine compartment, and front wheel wells and inside fender pieces. Engine is MUCH quieter and road noise is definitely noticeably reduced without even moving to the inside of the truck yet. I can't seem to justify yanking out the interior right now when I'm going to do a complete interior swap later this summer.
One minor and very easy to do mod I did over the weekend was a double rubber weather strip install on driver/pass doors to reduce air noise coming off the front pillars. These hoes dont have the front door tucked under the A-pillars like some luxury vehicles I've owned, so they are exposed to that constant wind noise. Over time your rubber wears thin too - you'd be surprised at the results I have gotten, will post how-to pics but it's very simple. All you need is an hour or so to burn hunting the right piece from a junkyard and cut it correctly.
BOSS
BOSS
BOSS
Dallas
Snapped a couple today before I do the body drop
BOSS
BOSS
BOSS
Dallas
(removed the spacers....don't need another wheel stud incident LOL)
Another random mod I did was remove the spring isolators as suggested by a certain someone :Handshake: Honestly - I measured about 1/4 inch drop conservatively, could be a slightly more. I ended up splicing a piece of a rubber hose off, then slicing off several strips which were half thickness of the hose, and wrapped them around the top of the spring with some 3M high temp adhesive to cut down on any squeaking and metal/metal contact wear. It was a serious pain in the ass and sticky as hell too :supergay:.
I would have said it's a all pain, no gain mod but I used this mod to also decrease the difference in height of the driver side versus the passenger side rear of the truck. I added more rubber on the driver side to lift it up a little since these trucks tend to be taller on the passgr side. I personally think it's because of the pull on acceleration driverside upwards, thus compressing and decompressing the body mounts. Who knows, if you figure it out let me know!
BOSS
NathanJax
Vacation Nathan
Jax, Fl
Boss, can you give us a "mod list"?
Nice truck!
Thanks
DarkTahoe00
IN
Thats is a Hot looking Hoe you got Boss! Where did you get and what kind of running boards are those? Excellent work on the hoe man!
BOSS
BOSS
Dallas
Thanks man, the running boards are from a custom set like they make for Lexus RX330.
Thanks for the props, I definitely enjoy the "clean looking" comments bc that's precisely the look I'm going for.
But here is a list of what I have so far, alot is changing though:
-Custom body color matched running boards (Lexus RX330 style)
-Clear Corners
-FlowPro true-dual exhaust with Corsa tips
-K&N full CAI
-BB Tune
-Level III transmission build with all the kicks
-Dynamat'd hood, fenders, doors, firewall, engine compartment
-Underside of the body Dynamat'd firewall to rear end (even under tranny)
-McGaughys 3/5 drop (spindles, keys, springs, Belltech Street Perf shocks)
-DJM Shock relocators
-Rear spring isolators removed for @ 1/4in drop
-LED tails/3rd brake light
-24x10 U2-35s (old rivet style) with 305/35/24
-Dual weather stripping on A-pillars (windy where I live, cuts down wind noise significantly)
-Removed OnStar internals - installed dash cubby
-Pioneer AVH-4000DVD Double-DIN (custom dash fit by JKMotorsports)
-JL Audio VR650-CSi Components (Front Doors)
-Kenwood 6.5 3-Way (Rear Doors)
-Pioneer 10in Subs powered by 1k Pioneer amp (can't remember model right now lol)
-Viper 5901 Alarm SST 2-Way
- - Remote Start System
- - Audio Glass Break Sensor
- - Digital Tilt Motion Sensor
- - Mini-Piezo Siren
- - Invisibeam® Field Disturbance Sensor
- - Backup Battery System/Siren
- - Window Automation System
That's it so far :rocking:
BOSS
DarkTahoe00
IN
So just that I understand correctly their not from a Lexus but by a company that makes them for Lexus I'm understand that correctly?
BOSS
BOSS
Dallas
CodeB4U
Houston, Tx
That's a nice truck. My brother has the same rims in 26's. What are the names of those rims?
BOSS
BOSS
Dallas
Cool, they're U2 35 series but they are the old rivet style that U2 no longer makes. I picked up an extra set of center caps just in case mine are stolen! :D
Some plan their retirement, I plan the life expectancy of my center caps!
BOSS.....
ChevyGirl
SW MO
BOSS.....
LO!! I just orded an extra set of center caps for rims
BTW Sweet looking Hoe!!
BOSS
BOSS
Dallas
Your hoe is hella clean.
Thanks for the props guys, can't wait to do more. It's like an addiction...
Is there a TahoesAnonymous group I can join? OH WAIT, I'm here. :D
BOSS
Eickybobby5050
