I checked the Posts & Never got what I needed
zieglerj-pdm-specialist
in 100 degree sandbox
Has anybody ever connected the HID head lights. I bought HID's for my Low, High, and Fog lights. Also Last year I installed Halo Head lights and tinted low beams. Is it easy to install these I think that the light plug in from the Vehicle plugs into the amp box and the HID lights plug into the hid light and mounting into the head lights. Then After I'm done installing the HId lights what is the easiest way of to adjust the lights angle left to right and up to down. Thank for your time and take care.
OHSIXX
Milwaukee
You are not even posting in the right section!!!!
Try searching!
NathanJax
Vacation Nathan
Jax, Fl
You have threads posted in all 4 sections (91-99, 00-06, 07-14, and 15+). What vehicle do you drive? We can't help if we don't know which vehicle you're talking about.
Pockets
West Ga
YukonXL04
The Riverboat
Arlington, TX
do you have the relay harness with the kit as well? or just the HID bulbs and ballasts? if you have the relay, then you will have 3 of them, 3 + wires and 3 - wires, connect these where ever you wish to get power from. I hooked my + up to the factory distribution block by the power steering reservoir. next you will hook the relay harness up to on of the factory headlight plugs, from there it will have a cable that goes to each side of the truck. These will go to your ballasts. And the ballasts have plugs that will then plug into your bulbs. screw the bulbs into the housing and your all done. you will be doing this 3 times because your doing high, low and fogs.
BadDaddy2003
