Need mad help...
DevinTheDude
I have a 2008 Yukon Denali. I've seen the McGaughy 2/3 lowering kit but honestly thats not low enough for me. I was told you can put a 3/5 McGaughy kit on it but you would have to do some custom work. Does anyone have any other suggestions as to what kit or if i could even lower my denali with a 3/5. I have it on 26inch rims and i was wondering if they would rub from being lowered. Thanks for your time.
Effeckt
Resident Cards Fan
Phoenix, AZ
Welcome the forums first off. I'm not sure as I don't have a NNBS but I'm pretty certain that you have your facts correct. I seem to recall that the 2/3 fits without any changes but anything lower will take some work to fit. I will let the others chime in that have a little more knowledge with your body style though.
NORCAL SS
SUV SUSPENSION GURU
3/5 id go the lowest on it. ive done the belltech on them on 305 25 26 3/4 worked out great.
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
Welcome to the forum! :cheers:
I went with the Bell Tech 739SP kit and the only custom work involved trimming and using a heat gun to re-shape the plastic fender liners. The front fender lips behind the tires also needed to be slightly massaged with a rubber mallet. If you have shorter tires than my 305/30/26's the rubbing should be less of an issue... Here are pics of mine at 3/4.5
I just realized this was posted in the NBS section... moving it to the NNBS section instead may get others with 07+ hoes/kons to chime in. :Handshake:
DevinTheDude
DevinTheDude
Yo... Thanks for the help fellas... I'm going to post it up again in the right section this time. Your drop looks hella clean man. Looking forward to doing that. I have Vellano wheels as well. Hella dope!!! Real rim shit right there.
rossida
