NCTyphoonKid
Trinity, NC
Took it to my pond
01ssreda4
Getting rid of the flaky paint on the center console bezels. Damn Denali yukons all have it, even new bezels sitting in storage long enough scratch very easily. figured repairing mine was better the buying new/used. Went back with black instead of grey.
a4edwin
ny
Had to replace the bolts on the trailing on brackets. Guy that installed it used the original long bolts that were used on the stock suspension. Kept hearing a sound in the rear suspension and turned out it was that. Went to Home Depot and bought replacement nuts and bolts.
Z-56 Hoe
What do I do????
Houston
I would get grade 8 bolts!
Z-56 Hoe
What do I do????
Houston
Rides a little stiff, but new shocks are needed so hopefully that will help. Gears are on the horizon.
What length shocks are you gonna get?
---------- Post added at 07:49 PM ---------- Previous post was at 07:48 PM ----------
Got my longtube headers installed I really love it
What brand did you go with? I love mine.
chauncey0337
MLT, WA
Changed my oil and filter today and since I had the hood up, I thought I'd check out my rear washer pump since it has not worked for some time. Pressed the button and the washer fluid shot out towards my drivers side view mirror! Seems as though the hose connection that is behind the electrical box had come loose. Works fine now. Much easier fix than I thought!
Big Buttons
The SS Burb
South Texas
Took out my 500lbs box because one of my subs is damaged. Also want to see how much faster it'll run at the track. Spins a lot more on the street now lol.
Yukongk
NY
Finally got my 20's!
No idea why the last owner had so many weights on the outside...afraid to remove them, not sure what I'll find under there.
JochenWoern
Sacramento, CA
WOW, that many weights and on the outside? Why would anyone put them on the outside.
Hope your whells are not bend to be that much out of balance in order to need that many weights.
CKendrick
