Yuko04
"SquareBODluvr"
MN
6 hi mod done!
Pretty cool little trick!
Ita work!
amtrucker22
Got this little problem fixed today. I was doing about 2 mph in a turn lane when the truck started pulling like crazy to the right. The rear bolt for the front right upper control arm was just gone. And about 5 minutes earlier I was doing 75 over a pretty high bridge.
Yikes...
Yukongk
NY
DANG, ........ Life must be rough if you have your own lift at home in your garage. ;-)
---------- Post added at 11:55 PM ---------- Previous post was at 11:54 PM ----------
Drill a small hole in the bottom of your fog light in order for the water to drain out. This should eliminate future floods as well.
These darn things NEVER seem to be watertight.
Great idea! Any particular place or just anywhere in the bottom of the light? I might go a step further and attach a rubber tube to make a vent.
Yuko04
"SquareBODluvr"
MN
4 different OEM FOGlights in the last 2 years. They all leak eventually. Ive siliconed, taken apart and resealed. They just leak. And when they are air tight. The moisture from your has no where to go and then they fog over. Drill a hole and be done.
---------- Post added at 11:57 AM ---------- Previous post was at 11:54 AM ----------
It is rough.......Im black...you dont even know the half of it...
LOL.[emoji1]
Its simple bro. Saved for 10 years to have the shop of my dreams. Never had a new car and have worked on the side to make extra loot. Having a wife on the same page has mad my life easier.
TailHook
Tattooed Millionaire
Arizona
Push bar back on after a short hiatus...
YukonXL04
The Riverboat
Arlington, TX
I trimmed my fog lights to fit a projector, had to trim a bit and then heat the plastic to mold it around the projector. I'm happy with the fitment, now I gotta build out the housing a little bit to enclose the projector. From the front you can't really see much difference, behind is a different story lol
Anyone know how to seal around the bulb on a h1 projector?
Tahoewhat
Ballin' on a Budget
TX
LOL.[emoji1]
Im sorry but that made me laugh, was not expecting that as a comment back. Just shows hard work pays off. Mad props to you my man.. Very nice shop as well.
Do tell? What projector?
JochenWoern
Sacramento, CA
LOL.[emoji1]
I am just jealous, but very happy for you!!!! It is a great looking shop you have.
Yuko04
"SquareBODluvr"
MN
Dont be jealous, but thanks for the props. And if your ever around my way. .. I got your back
---------- Post added at 08:12 AM ---------- Previous post was at 08:10 AM ----------
It was the only funnyman comment I had at the time. Glad to make you laugh.[emoji1]
---------- Post added at 08:13 AM ---------- Previous post was at 08:12 AM ----------
Jonas is white. Just thinks he's black.
Oreo pimping is my game!!![emoji1][emoji1][emoji1][emoji1]
YukonXL04
The Riverboat
Arlington, TX
I originally planned on using the depo projectors, but It turns out the spec d tuning ones that came with my headlights have better output. I ended up making a custom curved flat cutoff sheild for it and it helped the output some. really its just a way to put these projectors to use lol
Tahoewhat
Ballin' on a Budget
TX
ahh, so you just used your headlights original projector. Good way to reuse items.
YukonXL04
The Riverboat
Arlington, TX
Yea, Once I made the curved cutoff shield for the projector the output surprised me. I really thought it was much worse before my mini retrofit.
criffaaa1
Got pics of yer work?
sent from my Crifftastic $3
Tahoewhat
Ballin' on a Budget
TX
didnt do anything, but got to drive a ZL1 Camaro that had 3k miles.
Yukongk
NY
Cleaned my interior
dizhai
