seven9st surfer
Milton, FL
Completely disassembled and correctly reassembled the K&N CAI that the shop apparently screwed up when they installed it for the previous owner (mass air sensor installed backwards), cleaned the air filter, de-rusted and sealed up a turn signal socket that was going bad, fixed my HID headlight, replaced a burnt out license plate light, replaced a rusted out wiper arm, and repaired a wire to my OBD port that somehow got cut in half so now my Bluetooth reader works again. Good day.
EDIT: and keep the LEDs, YukonGK, I have the same ones. They look great.
02 Burb
California
+1 for the leds.
Removed the roof rack and used m6 set screws and silicone to fill the holes and re-sprayed some paint on the front to fix it up.
ryan04z71
Got the torsion bars cranked, fresh alignment, got some 285/70s installed. Tested the 4wd a bit.
Sorry for the pic of the camera, uploading from my phone right now. Haven't uploaded pics from camera yet
uploadfromtaptalk1396231024852.jpguploadfromtaptalk1396231074866.jpguploadfromtaptalk1396231151633.jpg
Sent from my XT1080 using Tapatalk
Yukongk
NY
Rinseless washed her today. I think I'm going through an "anti-LED" phase and am rocking the smoked stock tails for a few more days lol.
Yuko04
"SquareBODluvr"
MN
Getting ready to do 6 hi mod that I've been getting around to for the last year[emoji57]
Darn blocking of license plates! I was going to come teepee your house
Yuko04
"SquareBODluvr"
MN
Its a pic I sent to a guy last week. He wants a front end like mine. Never can trust the CL guys.
Yukongk
NY
Realized my brand new fog light has a flood inside of it......
JochenWoern
Sacramento, CA
DANG, ........ Life must be rough if you have your own lift at home in your garage. ;-)
---------- Post added at 11:55 PM ---------- Previous post was at 11:54 PM ----------
Drill a small hole in the bottom of your fog light in order for the water to drain out. This should eliminate future floods as well.
These darn things NEVER seem to be watertight.
seven9st surfer
Milton, FL
Got this little problem fixed today. I was doing about 2 mph in a turn lane when the truck started pulling like crazy to the right. The rear bolt for the front right upper control arm was just gone. And about 5 minutes earlier I was doing 75 over a pretty high bridge.
attachment.php
attachment.php
JochenWoern
Sacramento, CA
attachment.php
attachment.php
Guess you were pretty lucky!!!!!
Bwaldron
