Parts
swtz71
Mass
Tony
I need sway bars, shocks and shock extenders for my 04 tahoe 4x4
Can you help me out with a total? I have a 2/3 drop with keys.
Thanks in advance.
NORCAL SS
SUV SUSPENSION GURU
Tony
Thanks in advance.
NO PROB
front and rear swaybars djm
front/rear belltech sp shocks
Rear Belltech shock extenders
$650 shipped
If you decide for the shorter djm endlinks which fix swaybar angle and handle better its $85 extra.
If rear end is bottoming out and you decide to do free travel mod I have a bumpstop that bolts into a existing hole on axle its $25 shipped and will prevent axle to frame hitting
swtz71
swtz71
Mass
She does bottem out over speed bumps but I just thought that was because my shocks are junk.
The shorter end links will stiffen the ride?
NORCAL SS
SUV SUSPENSION GURU
endlinks help the ride and reposition the swaybar so it doesnt point down to ground like now and better feedback in corners.
If you can take a picture of the rear bumpstops and how far they are from axle. if they are stock height by cutting them down ride will improve since will have more travel.
swtz71
swtz71
Mass
---------- Post added at 11:46 AM ---------- Previous post was at 11:39 AM ----------
I cut them when I put in the drop
NORCAL SS
SUV SUSPENSION GURU
yup no travel you will need to do the free travel mod (you can google for pics) and the rear endlink kit with my bumpstops and you will have a 10x better ride.
---------- Post added at 08:56 AM ---------- Previous post was at 08:55 AM ----------
$650 shipped
add in endlinks/bumpstops they are $110
And done and will corner MUCH better
swtz71
swtz71
Mass
sweet !! total me up but be gentle please haha I could use a better ride, right now she is like an old caddy floating around.
swtz71
swtz71
Mass
tony
should i try to change to spindles instead of my keys i have
or am i ok
also what other options are there for the front?
thanks
NORCAL SS
SUV SUSPENSION GURU
Control arms with belltech sp shocks. Adjustable 2-3 inches and excellent ride. Thats 440 shipped. Spindles belltech 280 shipped for 2 inches is another way
swtz71
swtz71
Mass
Ok so if I wanted to do spindles shocks end links and sway bars?? Or do I not need the bars right now??
NORCAL SS
SUV SUSPENSION GURU
you can do the swaybars later
you can do
spindles
shocks front/rear
endlinks
bumpstops for free travel mod
swtz71
swtz71
Mass
How much is all that??
Thanks
NORCAL SS
SUV SUSPENSION GURU
spindles
shocks front/rear
endlinks
$615 shipped to your door
swtz71
swtz71
Mass
Sounds like a good plan.
vsaravia
