Cheap fix for a door panel screw up?
FishinCricket
GMC Salesman
The Ozarks
Everyone feel free to chime in and laugh at me, I think I just cost myself what I was trying to save myself!
I was replacing the power window motor and regulator on the driver side of my 2003 GMC Yukon and somehow managed to screw up the ideal sequence of events and tried to pull the power window switch out of the drivers door too early.. I ended up breaking the little clip at the bottom of the window switch panel that clips into the arm rest portion of the door panel...
Now that I've put it all back together the power window switch panel is just hanging loose with nothing to clip into. The armrest is removable but the parts department can't get just the armrest..
I can probably epoxying the part or something, is there any other inexpensive fix you can think of?
BaMaDuDe87
Bama
I'd say junkyard or epoxy are prob your best bets.
Sent from my Galaxy Nexus using Tapatalk
YukonXL04
The Riverboat
Arlington, TX
From your description it sounds like the damage is on the panel that holds the switches, that clips into the armrest... right?
FishinCricket
FishinCricket
GMC Salesman
The Ozarks
Yes, the end of the armrest itself, past the foam is the white square plastic clip housing.. Here's the broken end of it:
Rivieraracing
Ouch, that sucks! Was hoping you were talking about the tabs on the switch itself and not the armrest but I figured it was something different than I was reading! If it's hard plastic, epoxy might be your best bet, super glue won't be strong enough!
YukonXL04
The Riverboat
Arlington, TX
Yea that's not going to stay with epoxy... lol... you can lift the switch up and shoot some hot glue under there... won't be permanent And still stay in place. I have done it to others before
Gzes
the drifting 2dr
Wichita tx
I think plastic weld will work just get it hot enough to bond. I had to remake where my under column panel goes and it turned out great. I used zip ties as the material and a torch and metal strip as the heatin element
YukonXL04
The Riverboat
Arlington, TX
It will probably hold as long as you don't take that panel off ever again lol. Good luck. I hope OT works for you
FishinCricket
FishinCricket
GMC Salesman
The Ozarks
Luckily for me I've got access to a body shop and the stuff I used is the same stuff they use to deal body panels together...
Still feel free to wish me luck though. lol
---------- Post added at 02:29 PM ---------- Previous post was at 01:58 PM ----------
The epoxy appears to have done the job! :). This 3M stuff:
YukonXL04
The Riverboat
Arlington, TX
You could try cutting a piece of thin metal to cover it, spread the epoxy all over, lay your metal down then after if dries cut the slot back out and that should hold.
FishinCricket
FishinCricket
GMC Salesman
The Ozarks
Yeah, that's what I was thinkin...
For now I double sided sticky taped that lil bastid.. It'll hold for now.
Jlaughtr
Deming, NM
I have broken the same piece just from using the door handle to shut the door i guess. Can you not just buy the piece or do you have to buy the whole door panel? I'm even thinking of just running an epoxy or glue on the rim of the panel and just sticking it on there without using the clip..
X-ray Nerd
