Post:All lowered tahoes 4dr and 2dr
CbChevyLt_99
paulding
ill add mine to the thread! :D
belltech street performance shocks, djm flip kit and mini notch, 2" djm spindles, belltech drop springs 3" with coil cut, 20x8.5 boss wheels wrapped with 245/35/20. poly urathane bump stops. few other mods as well. and ill be polishing brake cali's this weekend
JonDeere
Dropped 3/5 on 22s. I bought this all stock two and a half years ago and i have done everything myself also have four 15s and a massive box inside
314_kamper
5/5 drop with 255/50/17 gonna go lower and smaller tires 245/45/17 fronts and 275/40/17 on the rear
RoRo
TX
how did I miss this thread......
2" DJM springs with 1/2 coil cut off
2" DJM spindles
DJM flip kit/notch
20x8/9.5 245-40/275-40-20
98blackbell
FL
Here is mine......
This is how it was original setup. 15" centerlines on 32" tires stock suspension.
Picked up the 20's dropped the step bar.
Then did the 4/6 DJM drop, had to add 1" helper hangers to level it out.
Here is my 96 I just picked up. She needs some work. But it's mine. It has lower control arms in the front and a leaf kit in the back. It rides like shit. I need to find a set of stock leafs. The kit is a Chisholms. Anyone heard of them?
wtbtahoe
My '99 LT has only 14,000 original miles. Found it up in New Hampshire. The original owner installed the DJM lowering kit, blacked out bumpers and the SS grille. He also debadged it and put a flowmaster dual exhaust on it. I put on the American Racing wheels- 8/9's X18" with Michelin 255/55's and 275/60's. Wanted a little more sidewall for a better ride and a bit more of the retro look. Took off the roof rack and the hitch. Looks like RoRo and I had the same idea!
JonDeere
Any or yall lowered 4doors on 15" wheels? If so whats the width of your rims and what tire size do you have on the rear. I want to find some thet dont stick out past the body
red02chevy
Lubbock
My '99 had 15's. I ran 15x7 wheels with 235/75R15 tires
JonDeere
Do you think a 15x8 would fit? And is 235 the widest rear tire that would tuck?
red02chevy
Lubbock
An 8" wheel with the correct offset would work. Even a 10" would. With the correct offset you could probably run up to a 285 tire
JonDeere
Alright ill have to find someone that knows how to figure out my off set. Thanks
Phlipnstik
