Driver Information Center (DIC) Display
HOG4FUN62
the DIC on my 2007 YUKON XL started flashing on and off and now it doesn't light up at all. All other functions and lights work. I've checked fuses and all are good. I think it has to be a loose connection in the wiring but I do not have the wiring diagram to know where to start and I DO NOT want to just tear out the whole dash if I do not have to. Searched the forums here and no final answers on how to fix.
Regency
Are the buttons for the DIC flashing or the gauges?
H
HOG4FUN62
Neither the buttons nor the guages are flashing. The digits themselves on the DIC are out and flicker on from time to time. The buttons seem to works when the display is on so I assume the computer is still feeding the display. The light-up display is out almost all the time though.
doubletapdrew
You'll probably need to have a dealership look into it. Our 05 Sierra did the same thing and it was from the chipmunks deciding wire insulation from under the fuse box would make a good nest.
ulakovic22
Argyle, TX
Anyone ever find a resolution to this? My 2007 Suburban started doing this as well. At first I thought it was the alternator, but when I took it off and had it tested everything was fine. Drivability is not effected at all, it's just the lights flash on and off.
Xtremels1z28
My 07 Denali xl just started doing this but I havent looked at it yet. Figured I would start here before I pull out the cluster.
GM Customer Service
Michigan
Xtremels1z28,
Hello! I understand that you are looking to resolve this vehicle concern yourself and I may not be able to give you any technical advice but if you find that you need GM Customer Care, we are only a private message away.
Regards,
Jennifer T.
GM Customer Care
Xtremels1z28
Xtremels1z28,
Regards,
Jennifer T.
GM Customer Care
Jennifer, I cant PM you till I get 10 posts but I would love for you to help me with this. Thanks, Anthony
---------- Post added at 07:56 PM ---------- Previous post was at 07:00 PM ----------
PM sent
GM Customer Service
Michigan
Xtremels1z28,
Yes, I am happy to assist. You may contact me via email at [email protected] and put Attention Jennifer T. in the subject line. Also, in the email please include a brief overview of your concern, full name, address, phone number, VIN, exact mileage, and preferred dealership.
Thank you,
Jennifer T.
GM Customer Care
ulakovic22
Argyle, TX
To anyone still having issues with this I got mine fixed this past weekend. The issue is not wiring related, it's something with the "mother board" for lack of a better term.
The dash cluster when you take it out breaks down into 4 pieces. The back, motherboard, gauge face and finally the clear cover on the front. The back and clear front come off easily just by depressing the tabs. You have to remove the needles to seperate the green motherboard from the gauge face. The issue of the DIC and gear selector going out is because the solder and chip bascially burn up. You can replace the chip when you resolder it or not. I had mine replaced and all is well. There is also a guy in Dallas that you can send your cluster to that will fix it for about $100. PM for details if you want since I'm unsure of the non-sponsor rules.
stbdtack
I also just starting having this issue with my 2007 Yukon XL. Will be taking it to my local mechanic whom I trust sharing this information and will share back findings to the forum. Very happy with my vehicle at 97,000 miles with not too many issues since new. Glad to find this forum as I intend to keep the girl going as she is my Airstream tow vehicle and upper midwest troutmobile.
stbdtack
Had my local mechanic check it out and is as ulakovic22 stated. The electrical board needs to be refurbished. I am not a DIYer so about $400 to fix.
ulakovic22
Argyle, TX
$400 is a lot to do the job. It literally takes 45 minutes to fix, just pop out the cluster, fix it and reinstall. If you figure $100 to fix it, you are paying $300 to R&R the cluster. If you haven't already got it fixed give it a shot.
stbdtack
Thanks for the encouragement but like I said I am not a DIYer. I am in the Chicago area and my mechanic said the cost for the refurb place they use was about $275 and an hour to install. He did say they have done this more than a few times for this era GM truck.
buckbadly
I see this is an older thread, but you wouldn't by chance have a pic or know where I can find one of the chip that needs resoldered? I just started having this issue with my Tahoe and I am fairly proficient at soldering so I was gonna give it a shot. Will it look "burnt" or melted? Sorry if this is a dead thread. Just trying to get this fixed.
Fred_e81
I know this is an older threat but this just happened to me as well. Only the electronic display went out and not the gauges. Go to ebay and look uptradesman2013. You purchase his services and send him the cluster to be fixed. He is located in Austin,TX. I shipped mine on Monday and had it back by Saturday and works as good as new. His charge was $50 plus shipping to him. I highly recommend his services.
ulakovic22
Argyle, TX
Unfortunately I don't know where to get the chip, I would imagine you can get them from the dealership, or at least that's where I would start. Yes it will look burnt, the guy described it to me and said it overheats and burns.
nofaz
Bismarck
I have a 2013 Yukon Denali and am disappointed with the lack of brightness on the DIC. I've driven other GM stuff of this type and they also have a very dim DIC during the day. Is there a mod out there to improve the brightness? I'm betting some lawyer told an engineer how bright it could be!
BadDaddy2003
