HeadLights ????
SunlitComet
OBS Jedi-Do Good
unknown at this time.
I personally use Anzo's myself.
I have:
http://www.amazon.com/111004-Chevrolet-Crystal-Headlight-Assembly/dp/B0015PPZMC
www.amazon.com/511048-Chevrolet-Amber-Parking-Assembly/dp/B0038B48X8/
And added the tails to:
www.amazon.com/311004-Chevrolet-Clear-Light-Assembly/dp/B0015PTTZ6/
I also converted to a led compatible flasher unit so I can cut all the ballasts of the off.
Elpescador100
Elpescador100
you sure do have some purdy lights... Thank you now i have some sort of direction..
YukonXLPerk
Brother in law just bought an LED headlight set. I think they are terrible cause they do not throw any light. He likes them cause they make the front his Yukon xl look cool in the day time. I would rather have visibility over coolness factor. IMO
Pick what you like, you have to live with it.
Beechwood
Michigan
I have:
I want these tails... can you expound on why you want to cut off the ballasts? I am considering replacing all exterior bulbs with LED's anyway and realize I would need an LED compatable flasher, just didnt know the advantage to getting rid of the ballasts.
SunlitComet
OBS Jedi-Do Good
because you get a led compatible flasher that will flash at a fix rate regardless of load, the ballasts become unnecessary. so instead of them coming loose form there tape mount I just cut them out. Saves a pound or two of weight if you got the LED fronts from anzo as well. Just thinking Eco-freindly.
varminpoolteam
