some custom boxes ive made before
josueh95
josueh95
That amp rack is sick. How did you mount the amps to the floor? Also, what secures the cover from moving?
amps are mounted with a plain sheet of mdf wood drilled to the carpet but it actually makes pressure and secures itself..the amp rack is help by its own weight and the amps basically keep it from moving but it doesnt budge by itself
NaomiSays
Hot Tamalé!
Wow, this is some really high quality work. You have some great skills, thank you for sharing. Keep up the good work, looks great! :thumbsup:
DCT
Thanks. Are there any wires or fuel lines under the floor pan I should be worried about.
josueh95
josueh95
honestly couldnt be sure about that but i dont use long screws just any thing long enough to get a tight fit
JeffK
