Diff Covers?
Z-56 Hoe
What do I do????
Houston
Plz update us on if it cleared because You are lifted or whats the deal???
YuCanada
Nunavut, Canada
I don't see why it wouldn't fit non lifted.. I don't have any other picture the Tahoe is gone. When I ordered it online, I did a compatibility check and it said it would fit.
a4edwin
ny
wouldn't the company be able to answer that question?
Z-56 Hoe
What do I do????
Houston
A few people on here with non lifted Tahoe's have tried to no avail
Travieso
Travieso
Boooooooost !
Los Skandeles, CA
Well guys i think i finally found the solution to having a custom Diff Cover that will clear sway/panhard bar
http://www.ebay.com/itm/Differentia...Parts_Accessories&hash=item19dddec49c&vxp=mtr
vjr021
Clearwater, FL
Any further progress on this subject?
I want to do the Mag-Hytec covers as well, but I hear they won't clear the Spohn Panhard.
Travieso
Travieso
Boooooooost !
Los Skandeles, CA
I doubt if a Mag-Hytec Cover will fit, this one barely clears the Panhard bar, so i would say no on the Mag one.
When i get a few funds i'm gonna purchase this.
vjr021
Clearwater, FL
I emailed Mag-hytec directly, they confirmed it will not fit with out "modification".
I asked for clarification, but they said it is custom work, they couldn't answer.
I would think spacing out the panhard bar is a bad idea.
Thoughts?
Travieso
Travieso
Boooooooost !
Los Skandeles, CA
IMO I wouldn't mess with the panhard/swaybar at all. if you look at the Differential Cover from ebay it only has 0.5 qt. over stock, im pretty sure the Mag-hytec cover has alot more volume then that, that's probably why it needs "modification" I kinda wish i found this Differential cover when i was building my rear end. :rage:
THE YETI
Director of Operations
South FL
I had a slim model of a diff cover, can't remember the brand. It wasn't a Mag-Hytec though. It was about 3/4-1" slimmer than the normal diff cover.
candyman74
arnold, mo
my truck is at the shop now getting the rear end done and ill tell ya if the ta 1807a cover fits or not
candyman74
arnold, mo
Well damn the luck. The ta 1807a diff cover will not fit with an aftermarket panhard bar. So I might have to have my bar modified
JeffK
