OEM 05+ Radiator Fans (ELECTRIC)
blueflamed03
Oklahoma
Black Bear also has the wiring harness. Luckily, when Justin did my tune, he turned the pins on :D
Mr.Martin
NC
Thanks for rubbin it in Mr. Martin... -_-
lol...where did you buy them and are they the 34 inch?
lol, I found them in a junkyard in winston-salem, NC. When I get bored I go through the yellow pages and get all the junkyard numbers I can then start callin em. Then when I find what I want I tell them "this place here has them for this price but you are closer" most of the time they will knock the price down ;)
Yep they are 34". Found out my 02 tahoe had the 34" radiator from the factory for some reason so out went the ls1 fans!
NathanJax
Vacation Nathan
Jax, Fl
I need you to call the junkyards in Jacksonville, FL. It's area code 904. When you find some, let them know "Nathan" will come pick them up.
PM their information... Thanks !!!
:Handshake:
:rofl:
05Yukon
Houston
Blizzard what kind of air intake setup are you running? Does it suck the air in from below the bumper?
OmarR
Indianapolis, IN
If you guys end up swapping in the OEM fans, get 2 radiator bolts (#11516931) to make the install easier.
This way, you have 2 bolts holding the radiator, and 2 bolts holding the fans in place.
yukonjacks
A Vegitative State
The Confluence
e-fan pins
Justin can turn them on for you. Shoot him a message.
I just had the pleasure of meeting Justin while he was in Pittsburgh, He turned my pins on, I ordered a harness kit also, currantly he's out of stock. I got my fans out of an 05 Tahoe, out of a salvage yard.
yukonjacks
A Vegitative State
The Confluence
Picked up my E fans off an 05 Tahoe 5.3L for $165.00 and a new 145 amp altenator for 110.
yukonjacks
A Vegitative State
The Confluence
I found out thats its better to wait till something is available for a better price than running out on an impulse purchase cause I saw it on the forum. Call me crazy but with the money saved on e-fans I can squander my savings on a new water pump, thermostat, idler and tensioner. My reasoning is, do it all while I have it torn apart, after all my vehicle is 9+ years old
navy34
Do you guys know if the the OEM harness is plug and play, or is there splicing involved?
NathanJax
Vacation Nathan
Jax, Fl
If you go to the junkyard, and get the oem fans, you should be able to gab the oem harness as well. It might be taped together with other wires, but you can carefully cut it apart.
navy34
Awesome thanks. A local chevy dealer is giving me a deal on the fans, 177, and 60 for the harness, so we'll see...
Buford bubba
