kschumake83
Orefield, PA
I've done worse, it does suck but the finished product is worth it. I have been rolling the tape with my fingers, I just keep rubbing it in one direction until it balls up and then I go over it with rubbing alcohol. I use one wet microfiber cloth and one dry one. You have to buff a bit due to the ghosting if you aren't going to repaint. I think I may get clear plasti dip to give the truck a matte finish and hopefully conceal the ghosted pin striping, debadging, and the spot where the previous owner got a bit over zealous wet sanding a scratch.
Sent from my Nexus 7 using Tapatalk 2
BubsXL
TN
Went to the tire shop to pick up my 375s. I also installed the new OEM GMC caps. Tires look BADASS
What wheels are these?
zieglerj-pdm-specialist
in 100 degree sandbox
Buying Dumb $hit, My nemesis
It's not what I did, but what some b*tch did.... pics uploading
---------- Post added at 11:26 AM ---------- Previous post was at 11:15 AM ----------
i look weird in the reflection because i was like half way sitting against the fence because i was parked so close, thats why my jeans look really tight lol
I ordered a new Carbon Fiber dash Kit which covers everything from the front to the back that will be covered with carbon fiber, The drivers side window dash cover all the way to the vents on the roof in the back has a carbon fiber circles. I paid way to much for them but it makes everything look different from every other Yukon XL Denali Dash it. It cover's the wood grain with Carbon fiber Looks really good but that's all it is it serves for looks and I should spend my money on things my family can use, I buy some dumb $hit that doesn't make sense sometimes? are any of you into the XBOX ONE or the PS4? I got both of those preordered with 5 games and a 12 month supply of PlayStation Plus. Write to me if anyone is interested in either system?? Thanks Much
BillBlatt18
Latham, NY
double post
BillBlatt18
Latham, NY
Did this to my rim and brand new nittos. Couldn't get my spare off to change it so said **** it and called AAA. He takes out the jack at the end and goes "Welcome to the hood"
Sent from my Galaxy S4 using Tapatalk
Sent from my Galaxy S4 using Tapatalk 2
livingez_123
Sandy, OR
I put a blue tarp in back and filled it up with demo debris from my RV remodel and then took it to the dump. The trailer is now 304 lbs lighter. Now I get to frame my new larger shower and plumb for a washer/dryer unit.
Pachanga02
Ny
Ouch on a new nitto tire.
far away sticker pic is far away
yes :D
mcquack2
Utah
So I drove 300 miles across Utah and back to go rescue my brother who blew a head gasket in his Saab. On my way there my transmission overheated, and I wasn't even towing anything! When I arrived there, I immediately did a transmission fluid change, man oh man was the fluid brown and burnt!
Towed the Saab back, but the transmission has been acting all weird now. High rpms when 'trying' to change gears, and not have success all the time.
Check the dtc codes, and sure enough I had the P1870 code for transmission slipping. Deciding what to do with that one now.
Bowtieduece
Hi everyone. New here just picked up my tahoe on Tuesday night. Here is a before after. Plastidipped the rims and bumper and removed the roof rack.
My next plans are to lower it and remove side moldings.
Sent from my Galaxy Nexus using Tapatalk 2
chauncey0337
MLT, WA
Welcome Jesus. Looks good man.
Yukonboy2014
Today, tuned my CB in the 'Kon. SWR is nearly 1:1 in the middle channels vs on 1 & 40, which are around 1.7:1..
Phlipnstik
