felixgun
Why not go 4300k for both? The lower the temp the more light output...
Geeze that really didnt hit me.Why not go 4300k for both? The lower the temp the more light output...
Thanks for all the great info, as I need to do something about these lights my Yukon came with.....they suck at lighting the road.
yeah, there's been a few members who have tried those and LITERALLY thrown them away...
You're in NJ so you are blessed with many great retrofitters in the North Jersey/NYC area.
There's lightmodz, lightwerkz, blackflamecustoms, and hidillusionz, all whom are recommended by TRS: http://www.theretrofitsource.com/recommended_retrofitters.php
Okay, so I've just finished reading this thread and found out I'm about to become a highly disappointed douchebag, these will be here Wed.
So how to fix? My wife wouldn't appreciate me raiding the Lexus for the lighting.
First thing to do is return them without ever opening the box and get your money back.
Second is to decide if you want a retrofit and if so what hardware you wish to use. (read how much $ you wish to spend)
You don't have to raid your Lexus for its lighting, all Lexus and other OE projectors and associated hardware can be bought from TRS, as well as aftermarket hardware if budget is an issue.
If you're not near a retrofitter, there are many that will undertake the work at a distance, although less precise if the vehicle isn't there, long distance retros are equally effective on the road.
If you're a DIY person you can also read endlessly on hidplanet to learn and try to tackle the project yourself. Although many have successfully done it, it does require a great degree of skill, precision, and attention to detail ... and mistakes are VERY expensive.
Why not go with the 25w ballast for fogs? Why risk it when a lot of people are getting their housings melted with 35w and 55w housings?
I want a smoked lens look, will these housings not work with the proper lighting retrofit?
You can certainly have the lenses smoked by a professional before the retrofitter seals them back up ... just know that any tint of them is going to rob you of lumens, the darker the tint the more lumens you'll lose. It's called the Corey Hart effect.
Here's a few lengthy threads by retrofitters of their work on different vehicles to give you some ideas of what's possible:
http://www.hidplanet.com/forums/sho...inting-Wiring-Harnesses-Headlight-Restoration
http://www.hidplanet.com/forums/sho...inting-HID-Systems-Technical-Support-amp-More!
http://www.hidplanet.com/forums/sho...rofit-Packages-amp-Complete-Turnkey-Solutions
http://www.hidplanet.com/forums/sho...ding-In-HID-LED-Retrofitting-Since-2003!-quot
I like to read these thread from back to front cause the latest projects usually show the latest available hardware.
