OEM 05+ Radiator Fans (ELECTRIC)
BlizzardX23
Sacramento, California
Just installed these on my 2003 Yukon Denali...I took the Clutch fan off...and this thing slid into place and I put the two mounting bolts in.
Estimated Install Time - 3 minutes and 46 seconds
Fit - PERFECT
Now all I need is the harness and for my "pins" to be turned on?
Tahoe03mm
Puyallup, WA
About how much did that set you back if you don't mind me asking. I'm curious on what you figure out with the harness. I'm also asuming the Denali is using the same radiator
NathanJax
Vacation Nathan
Jax, Fl
Price ? Where did you get them? Pics of install?
DETAILS MAN, DETAILS!!!!!!!!
OmarR
Indianapolis, IN
I am betting he got them from here:
Ebay Link
I also bought from him for $200. He will range from $200-$250, and they are OEM fans.
Blizzard, you do need a harness. You could make your own, buy an aftermarket like Nelson, or buy the OEM harness.
This is the OEM harness that I used:
If you want the PCM to control them, then yes, you do need the pins in the PCM turned on by a tuner.
Another option would be to use an adustable thermostat controlled setup.
BlizzardX23
BlizzardX23
Where did you get the OEM harness..Nelsons? Also...where did you run it...
I see the two plugs that plug into the fan..but how and where do the rest of the wires go? and the extra plug?
---------- Post added at 06:36 PM ---------- Previous post was at 06:34 PM ----------
Justin can turn them on for me...but that requires waiting on shipping...and my truck will then be un-drivable again...for god knows how long..and I dont have the funds to buy another PCM or whatever I may need... =(
Rollin Thunder
Banned for Repeatedly Insulting Members
Va Beach Va
I wouldnt drive your truck now in its current state with no cooling fan.
BlizzardX23
BlizzardX23
LOL...I already did...I just saw how the truck reacts when it overheats! :(
lol....
(Read on display)
ENGINE COOLANT HOT read on display with DING DING DING DING DING DING DING sound...thennnnn few minutes later...ENGINE OVERHEATED read on display with DING DING DING DING DING DING DING sound
YIKES!!!! I NEEEEEEEEEEEEEEEEED MY FANS ON!!!!!!!!!
NathanJax
Vacation Nathan
Jax, Fl
Justin can send you a PCM in the mail (you can pay for overnight) and then just return yours to him... There's a $100 core charge thats returned to you when you send yours back
And you still didn't answer my questions...
Where did ya get it?
How much did it cost ya?
Did it come with bolts to use or where the bolts holding the radiator in long enough to hold these in as well?
All you did was take your fan and clutch off? You didn't put anything in it's place?
BlizzardX23
BlizzardX23
$250...heres the exact fan I just purchased
http://cgi.ebay.com/ebaymotors/ws/e...0344765654&viewitem=&sspagename=STRK:MEWNX:IT
---------- Post added at 07:14 PM ---------- Previous post was at 07:04 PM ----------
ohhh...your wanting to do it...ok...you take the fan clutch off...
You know the stock fan shroud? You see the two bolts holding it to the radiator support? Theres one on each side...plus a bunch of plastic clips... All you do is take the fan shroud off...and use the two bolts..one on each side...the bottom of it has rubber pieces that fit into the bottom part of the radiator shelf...BAMM! Simple as that :)
The link above is the Fan Set I just won :)
---------- Post added at 07:19 PM ---------- Previous post was at 07:14 PM ----------
I wonder how fast he can get a new PCM to me...and what can be done to it?
NathanJax
Vacation Nathan
Jax, Fl
[/COLOR]ohhh...your wanting to do it...ok...
Yeah I had plans to do this and my tune until you lowered your Denali. Then I said screw it, I bought the rest of the stuff I needed. Then said screw it, got the rims I wanted, AND i just did another upgrade to my truck tonight ;)
Now I need these fans, the wiring harness, and the tune...
So it's all your fault, I blame it on you...
BlizzardX23
BlizzardX23
LOL....Glad I could help! ;)
...new upgrade tonight??? What did you do? lol..spill it!!!
Mr.Martin
NC
I found mine for 130! They look mint. I still haven't put mine on cause I'm still waiting on the harness.
NathanJax
Vacation Nathan
Jax, Fl
BlizzardX23
BlizzardX23
alright alright alright!!!! Im uploading now! lol....
I pulled out the construction lights just so I could take these damn pics! lol
---------- Post added at 10:16 PM ---------- Previous post was at 10:08 PM ----------
CKendrick
