Cabin air filter retro fit
pwtr02ss
Tennessee
I seen the other threads that people have done the retro fit on the 03-07 NBS and was curious if anyone had done it on a NNBS? I would like to put one in my avalanche because I have terrible allergies.
neutube
First of all I have NOT done this!!!
but others have from what I can tell and apparently the 04 and 08 have the same setup in the hvac unit except no door and added "ribs" inside. from what I understand you need to remove the initial hvac cover get two 02 filters, use a dremel and cut out the original door bottom dimensions, cram the two filters up there and then seal it up air tight (maybe with foil tape) - the guy who originally made the kits stopped for money reasons
I'll wait for others to chime in as I'm not going to start hacking under the dash just yet...
http://www.chevyavalanchefanclub.com/cafcna/index.php?/topic,57221.0/all.html
http://www.gmfullsize.com/forum/showthread.php?t=145137&page=3
Chrisalecia
Northern NJ
I did it on my 2010 Tahoe. It works great. Tony's links are what I used. It's a simple mod. I used my fein multitool for the cut. Just make sure you don't cut too far back. It should be a little wider than one filter. So you push one filter in and slide it back then slide the second filter in. Use cardboard from the box or a vinyl blind from a trashed shade to slide the second one in. The filters have a fabric on them that makes it hard to slide against each other.
I did it to get rid of the musty cabin smell. Use the Frame filter with the carbon in it - works great. I got flat stock aluminum at the Depot.
pwtr02ss
pwtr02ss
Tennessee
Awesome. I had read the threads with others doing on 03-07 just hadn't seen it on any nnbs. Chrisalecia do you have any pics of yours? And thanks for info and links
Chrisalecia
Northern NJ
So it did clean up the smell of the interior? I get a musty smell from time to time.
It helped the musty smell a lot but didn't get rid of it totally. I want to get one of those cans on spray to clean it out. I also read someplace you can install a relay that makes the blower stay on for a t time after you turn the vehicle off to dry everything out.
Kenric
Howell, MI
What is the part number of the cabin filters we need? I think I am going to try this in my '13 Denali.
Chrisalecia
Northern NJ
I didn't take a pictures but the 2 photos that Tony posted is exactly what mine looks like. I do remember seeing other photos online - if you search you may find them. It's an easy mod. It took me probably 2 hrs total and I took my time (measure twice cut once!!!!).
I'm glad I did it I think it has helped my allergies. Pollen is off the charts by me right now and the filters do make a difference.
pwtr02ss
pwtr02ss
Tennessee
I took a look under there and it is very straight forward. Thanks again guys for all of the help. I will try to remember to take pics when I do it and post back up here.
Chrisalecia
Northern NJ
These pics are spot on. In the first one you have to cut the plastic back to accept the filters. See the screw seat all the way on the left? That is the only screw to hold it up. the back of your plate gets notched out. I did it a heavy 1/4 inch and it fits perfectly!
Cut the plastic out. Smooth it down with some sandpaper to get rid of the fuzzies. Install the two filters. install your cover plate. get the flat plate material at the Depot along with 1" foam gasket. The 2" aluminum flatstock will take the foam gasket perfectly. You'll see, it really works out awesome. I was surprised at how well it all went together.
TheAutumnWind
I need this in my NBS! thanks for posting
Looks like GM is selling a retrofit kit:
http://www.performancetrucks.net/fo...bin-air-filter-retro-kit-gm-oem-parts-533295/
GM Part Numbers (latest style, straight bracket)
22759208 - Retro Fit Kit (bracket & screw) $35-$50 (confirmed this fits a my old 2005 NBS GMT 800 Sierra)
22759203 - Cabin Air Filter $26-$33
23101674 - Cabin "Carbon" Air Filter $26-$33
Only 1 filter is needed
GM Part Numbers early NBS's 1500/2500/3500 GMT 800 "L" bracket type (Older style)
52494070 - "L" Bracket Cabin Air Filter Cover (not sure if screw is included)
19257782 - Cabin Air Filter (QTY 2 half filters)
12489479 - Cabin "Carbon" Air Filter (QTY 2 half filters)
Conedaddy
