2000 Tahoe Z71 OBS AC issue
sphillips
I have a 2000 Z71 OBS with rear AC. The rear AC blows cold, but the front doesnt, barely cool. So the problem would appear to be some component particular to the front AC system. Air blows well out of the dash outlets, blower motor works on each setting from hi to low. All fuses good, compressor cycles on and off. Any thoughts?
Thanks
Grebbler
Parts is parts...
Michigan
Front Hot / Cold blend door actuator or dirty front freon orifice would be my bet.
If the compressors cycles constantly you could just be too low or hi on freon.
S
sphillips
The manual describes a "temperature door". Is this the same as the blend door?
Grebbler
Parts is parts...
Michigan
Yes.
There are typically 3 doors in the front not counting whatever they put in for DUAL Climate Control (His&Hers).
A Temperature door to blend hot air from heater core and cool air from the evaporator.
A directional door that swings from dash vents to floor vents to defroster vents and points in between.
A Recirculate (or Max Cool) door that switches between pulling in outside air (OFF) and reusing cabin air from passenger foot well (ON).
S
sphillips
Yes.
Thanks for clearing that up. The directional and recirculate doors work are working correctly, so probably the temp door motor.
S
sphillips
Well, I turned the ignition on without starting, and listened for the temp door as I moved the temp rheostat slowly from hot to cold and back. I could hear the motor come on and go off with each incremental movement. So, the motor is working, though I suppose that it doesn't mean that the door itself is moving properly, or at all. Does that make sense?
Thanks
vsaravia
