Upper ball joint
Asylum
Montreal, Canada
Should the protective rubber on the ball joint be more ballooned out?
When I squeeze it, should grease be *********** out? :derp:
A
Asylum
Montreal, Canada
So I'm guessing the only solution is to change it if there isn't enough grease since there's no grease nipple.
A
Asylum
Montreal, Canada
not at all, I was just curious. I'm gonna be changing out the two front hubs and disks, so I thought I should install the ball joints while I was there. No sense on changing them if they're still good.
Big Buttons
The SS Burb
South Texas
If they both look like that then they are more than likely still good. Maybe someone else with a NNBS can confirm.
Gzes
the drifting 2dr
Wichita tx
I would replace if you are gonna pop them if not let them be. shen you pop them they might rip the boot or jist spin around when you tighten. My lower ball joints for my civic cost $20 for both
InTruckDesign
SW CT,
If grease is coming out then the boot is more than likely torn and since GM thought it was a great idea to put non-serviceable ball joint in the uca's your only option is to replace. Good luck finding just the balljoint as they are pressed into the uca and are typically sold as the entire unit...balljoint and uca together.
Zed 71
Pacific NW
Yeah sucks they didn't put a zerk on there. The NBS has 11 zerk fittings which helps maintain equipment.
HeavyHoe03
