Do led front turn signals need resistors???
PHILLYTONE
Banned
PHILADELPHIA
Im replacing my stock front turn signal bulbs(3157) with some new 25 led wedge bulbs i just got. Can anyone tell me if i need resistors for the bulbs or will they work as is??? Once again not the drl's, just the turn signals. Also if they do need resistors, where can i buy them? What kind do i need? And what is the installation process? Any instructions? Thanks in advance for any help, links or pics!!
hassoun
Germantown, MD
you shouldnt need resistors. The LED you mentioned comes with a built in resistor. the only thing is if you plug it in and it doesnt work, try to flip the connection. Negative/positive make a big difference in the LED world
PHILLYTONE
PHILLYTONE
Banned
PHILADELPHIA
I got the leds from superbrightleds.com ... They are the 25 led 3157 wedge type....if i plug them in the wrong way, will one one be dimmer or brighter than the other way or will one way just not work at all?? That question sounds weird but i think you know what i mean...
---------- Post added at 03:10 AM ---------- Previous post was at 03:07 AM ----------
ANYONE VIEWING OR POSTING IN THIS THREAD, CHECK OUT MY POST IN THIS THREAD BELOW...MAYBE YOU CAN ANSWER MY QUESTION IN THERE TOO...THANKS FOR THE HELP
http://www.tahoeyukonforum.com/forum/showthread.php?t=12005&referrerid=4981
---------- Post added at 03:18 AM ---------- Previous post was at 03:10 AM ----------
I DONT KNOW IF THIS THREAD I JUST POSTED WORKS BUT IF NOT THE THREAD IS IN THE 07+ GENERAL DISCUSSION SECTION...IT'S LABELED "Help with LED rapid blinking problem" CHECK IT OUT
hassoun
Germantown, MD
yeh sometimes they are dimmer and sometimes they dont turn at all. i think. flipping them will fix the issue tho. i purchased all my LEDs from superbrightleds.com
tgt624824
I purchased LED's from VLEDS and resistors were indeed needed.
Hope that helps,
tgt
THE YETI
Director of Operations
South FL
There are four wires going to it what colors are the positive neg
Take a test light and find the ground and the flashing positive. That's the ones you want to connect them to.
wht06shee
I had to run a resistor for my turn signals, when I tried without resistors it did the hyper flash, but yes as mentioned above, it goes on - and +, I can't remember colors right now, but I wanna say the + was blue wire or a green, I can't think of the color off the top of my head.
NyCzFiNeSt1
Bronx, New YorK - Naples, Florida
i to purchased Putco 3157 running/ blinker led lamps for my '12 yukon denali, after install that night i noticed hyper flash on my mirrors and in the lamps themselves, kind of an eye sore, so i ripped them out and returned them the next day, rather then installing the resistors, shame cuz i really liked the light and color they gave. i should have just did the resistors.. =/
08grey
Yea resistors are easy. Go from positive to ground and tie strap them to the metal light adjustment rod. They heat up so don't strap them to any wiring. That metal rod works well.
Mlstammerjr
