Got a '96 Tahoe and am Looking for Ideas
gangrel1230
Massachusetts, USA
Back in December I bought a '96 Tahoe LT 4Dr. And its all stock now except for the replacement mirrors, blower motor, console and the bumper. The console was replaced by the previous owner with one that has a TV with VHS player and the housing on the console is starting to break. The bumper was replaced by the dealer before I picked it up because the original bumper was starting to rust through so they swapped it with the bumper off a GMC 1500 that was between '00 and '03 (Best guess).
So I need some ideas on what to do with this. It's my first car and I'm looking to have some fun with this truck but keeping it respectable and relatively cheap for now. I have been planning on putting on a brush guard and some KC lights but other than that I really have no idea what else to do.
Will post a couple pictures of it tomorrow when the sun comes up.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
why wait to post i am already up?
what to do depends on what you like. my first step would be to make sure the entire suv is as clean as possible. shine tall that is shinable and replace any clouded out light lenses. with led's if it interests you. what kind of fun did you have in mine?
Donnie Yukonie
Yates Caretaker
Sounds like a good start, what do you want your overall Look to be? Appearance , Functional? , Power? towing?
retorq
Kingman AZ
LOL he's from Massachusetts, if he attempts to shine it, the rest of the paint will fall off and the rust and rot will bust thru.
G
gangrel1230
Massachusetts, USA
I'm looking to make it look good and be functional at the same time. Doing something similar to your Yukon donyukon. I'm probably not going to do much towing other than the occasional trailer so for now I won't be doing a lift. But I'm looking at doing something for mudding and all around off roading fun.
Here are two pictures of it
cowboyzr2
Magnolia, TX
If you're looking to replace your center console, you could always try to find a 99-2000 Escalade/Denali Console... But not easy to find, much less for anything under $300 or so from what I've found looking for one. :(
I put a console out of a Lincoln Navigator in mine.
Or just go back with a stocker. I just threw one away actually...
G
gangrel1230
Massachusetts, USA
Thanks. I will look into those. Is kinda nice to be able to start from nothing but it also sucks at the same time because I have so many options. At some point though I will be putting bed spray on the rocker panels to keep that area of the doors from rusting anymore.
_Dylan_
STAY FROSTY
pictures no worky.
Dump that console. They are crap and just make the truck look older than your friends think it is.
Replace it with a flip down DVD unit. :lol:
There is lots of small things you can do. Is it 2wd or 4wd?
SunlitComet
OBS Jedi-Do Good
well my first things to do is clean up the lighting and paint and give it overall inspection of components and fluid levels and conditions. make a list of what you see and mention it here if there is a lot we can help you thru it. one other thing readily noticeable is that we well have to whip your suspension into shape. you are definitely going to need new leaf springs.
Donnie Yukonie
Yates Caretaker
Along the lines of what sun said , After all safety is the number one priority,
Its a great looking truck , and If you need any Advice on my build let me know ill be more than happy to share,
Once everything is checked out let us know what you find, If you don't have any real issues Get back to us and we will be more than happy to help you spend your money :D
thanks to this forum Ive dumped a lot into mine, and plans to dump even more
G
gangrel1230
Massachusetts, USA
I have 4 Rancho shocks that I need to put in so that should take care of some of the issues. Not to sure what to do with the paint as some spots are faded more than others. Everything in it is good. The brakes are good, we have had the fluids changed, and the wheels aligned.
So my list:
-Faded paint spots
-Spots of rusting on the lower body plus some surface rust on the undercarriage
-Broken antennae on the roof
-Rusting on rear bumper
-Broken aftermarket console
-Rear wiper switch and button is starting to break
-Driver's side handle is cracked but works
-Driver's side seat is ripped on the side
-Interior carpet is dirty (probably just needs some carpet cleaner)
-Fogged up lights (did a little bit of cleaning on them back in January so they aren't as bad as before)
There are probably more things, but this is what I can think of off the top of my head.
Just wondering what are leaf springs? This is my first car so I don't know much about them, yet. Hoping to learn a lot about my truck and other vehicles in general from the site and working on my 'Hoe.
SunlitComet
OBS Jedi-Do Good
antenna on a roof is something aftermarket unless you plan on using it somehow remove it and fix the hole. you can use polishing compound stuff to kinda brighten things up a bit. but adrees the rust for sure. you can use http://www.por15.com/ on the frame but dody is different so if you dont know how buy a book on diy auto paint and learn. replace your wiper switch and get your leaf springs replaced. start with that. oh and good interior cleaning.
leaf springs are the curvy thing in this guys hands. they support the vehicles rear weight.
EvAZRt
I changed my grill to an all chrome grill for pretty cheap and changed the lens of the running lights and head lights. Dropped in hid headlights and painted the bow tie on the grill. Since its your first car I am assuming you have no problem getting into you truck and you should ditch the running boards.
G
gangrel1230
Massachusetts, USA
I'm not going to drop the running boards unless I change them out since I'm not the only one that will be getting in and out. Plus they make a perfect spot to kick off the salt and slush in the winter so you don't wreck the paint. I will eventually change out the grill to something newer looking but that is one of the last things I do since that is only for aesthetics. The lights will get changed but not right away since they still work. I am considering putting in flashing ambers into the grill and maybe on the dash. And when I out the KC lights on the roof I will put a strobe or two up there.
I am currently developing/engineering a design for a new center console. When I have a couple ideas for it I will post the pictures of my designs (drawings).
G
gangrel1230
Massachusetts, USA
For now I am since I don't want to have to get it redone anytime soon. That is something I want to save for later when I have the money and when I am well on my way with modding it.
Escalade2007
