So why isn't the dimmer backlit/illuminated?
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
I took the light switch apart thinking there was a bulb out... but nope.
They simply did NOT put any illumination behind the dimmer in the first place???
agggghhh! WTH!
</end rant>
I guess I have to add a green LED to get an illuminated dimmer, anyone done this?
Max
Mile High
Denver
Mine dims :shrug: You can pull the bulb or install a resistor if it really irritates you.
Eagle
Eagle
EL PASO, TX
you have a light behind the dimmer itself? mine only has lighting around the rotary switch, and around the dimmer it doesn't.
thus it looks like there is a bulb out.
Eagle
Eagle
EL PASO, TX
Anyone?
do I have a defective switch or something?
or
Does everyone have only the rotary illuminated?
rigo_jones
going against
DENVER mexico
i dont think they illuminate. my 00 suburban and my 02 tahoe dont illuminate. the thing is that even if you put an LED behind it wont light up the little symbol because its just printed on.
Eagle
Eagle
EL PASO, TX
It actually worked fine on my 03 as they were translucent. I just didn't realize the factory illumination was so white, so I'l have to use white LEDs painted over with green marker instead of the green LEDs I have now.
YNOT
thread hijack.
are my window button in the arm rest lights and backseat console lights supposed to be duller than my dash lights, or are they going out?
rigo_jones
going against
DENVER mexico
i guess couse its an 03? we know alot changed after 03.
Eagle
Eagle
EL PASO, TX
maybe? However why did they go translucent FOR backlighting when they never backlit the thing!!! argggg.
At least i fixed it, now to buy a pair of raw white leds and replace the green ones.
Durobans
