First legit LED fog replacement for Tahoe Yukon (maybe)
soulsea
Bar
Reputable company: check
Proper heatsink design: check
Usable lumens: check
PnP: check
Here you go kiddos, what seems to be the first PnP led bulb with enough usable light to be a functional fog light and with enough heatsinking not to melt itself and everything around it. Available in 5202 amber or white: http://mtqinc.com/nokyausa/led_access/ledbulb/ledbulb.php
Not cheap apparently, a quick PN search came back with a site selling them for $130 a pair, also a few sets on ebay.
I haven't used them so not liable if they don't work as described, and I certainly wouldn't use them for critical lighting like low/high beam, but at least they should provide the best light those small fog housings allow for. Heat dissipation would still be a concern to me, but we won't know till someone tries it. :)
---------- Post added at 10:55 PM ---------- Previous post was at 10:49 PM ----------
On a side note, these will also fit the Escalade DRL function.
However I'd strongly recommend against running those for hours on end in those expensive headlamp housings before we really know what impact that amount of heat has on surrounding material. Also Escalade DRLs are capped so they would lose much of their advantage as the led is forward facing.
soulsea
soulsea
Bar
I think this is a pic of them in our actual fog housings:
MACHO
Seattle, WA
soulsea
soulsea
Bar
Come along come along ... if these fit my truck they'd be Guinea pigged already!
Elrey7698
Ill wait till someone has some feedback on these $100+ for 2 bulbs is a little rich for me..maybe after sum good feedback from a fellow member...on the other hand nokya does make sum great quality stuff..
99_Yukon
Michigan
Would these be very effective in a projector fog housing? I'll be the guinea pig if they would work just as good in a projector.
soulsea
soulsea
Bar
What projector fog housing are we talking about and what base socket does it have?
I mean it's a forward facing led so I see no reason why it shouldn't work the same way with or without a projector ... although it must be noted that depending on the quality and type of projector, heat dissipation might be an issue. Hence why I ask what type of projector.
soulsea
soulsea
Bar
I know those projectors very well, i used to have a pair to retrofit at some point. They're metal so you should be fine heat wise. I also think these bulbs are perfect for this application.
THE YETI
Director of Operations
South FL
might have to do these... :secret:
---------- Post added at 07:47 PM ---------- Previous post was at 07:25 PM ----------
edit.. wonder how they would look with some of their super-white headlight bulbs.. i dont really want to do HIDs without projectors on this beast.
soulsea
soulsea
Bar
You mean the blue coated halogen bulbs?
Blue coating does result in a whiter light, it does however rob you of lumens. The darker the coating to achiever a whiter light the less light will get though. Not to a dangerous degree, just slightly less light.
THE YETI
South FL
i dont think my Silverstars were blue coated? And they were a brighter white.
I guess I could just throw some scattered 4300k HID bulbs in there just to make Serge bang his head against a wall... I dunno
soulsea
soulsea
Bar
There are other ways to make halogen light appear whiter, it involves the actual design of the bulb and the way it burns ... it is those changes that give Silverstars and other similar bulbs a shorter shelf life, for that is the price they pay for the whiter light. So some brands do whiter halogen light by design sacrificing life hours, others by coating which keeps life hours longer but sacrificing lumens.
Drewphil
