3 inch body lift and 2-2.5 leveling kit
Tanlegged_juliet
Arkansas
I have a 2011 Ltz Tahoe with new 20 in rock stars can I put a 3 in body lift with the 2-2.5 front leveling strut can fit 33x12.50 nitto grapplers with out rubbing ?
08z71tahoe
Houston
unless u plan in installing it, the install will cost over 1k... body lifts suck...
fiatdale
Houstons Best
Houston
Body lifts arent too bad if you have the right tools. All thats really needed is a couple jacks, a few blocks of wood, and a few sockets. Ive done them with no power tools in as little as 7 hours (on a rusty older vehicle) and less than 4 with air tools.
I dont know a firm answer to your question, but I would think it should clear.
wbreaux
I have a 3inch body and 2.5" ccm level and I clear 34.8 with almost no rubbing
Zed 71
Pacific NW
12.5" wide tire is 317.5 mm. I don't think I have seen that wide a tire on an NNBS yet with a level kit. Wonder if that would clear the UCAs?
I would look like a beast if you can pull if off. Post pics!
What width and back spacing/offset are you running?
wbreaux
I'm running stock 20s and 34.5 x11.5. I have a friend with a leveled silverado on 12.5s and he rubs a little but not too bad. Not sure on how different the wheel wells are from silverado to tahoe though
Hurlz07Tahoe
Charleston, SC
I running a leveling kit with stock 20s and 305/55/R20s (12" wide tire) and don't have any problems at all after only minor trimming.
veteran111
