box sliding
swab
okie
what do you guys do to keep your enclosures from sliding? it normally stays in place but if i take off fast it goes straight to the back door.
BlueTahoe2001
Charlotte, NC
Yeah I just started another thread about this as well. Did not see this one...lol
tast101
Colton, CA
I don't have a problem with my box sliding and I just have 1 10" L7 in a vented box. But some people use L bracket to bolt it down.
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
I'm planning on using the cargo hold down bolts that are already in place... not sure if those exist on your body style...
S
swab
okie
yeah, i have those little triangle ring things but only one is in front of my box and doesnt do anything for it lol. my setup is only temporary, i plan on selling my current stuff and going all dd as far as sub/amp goes with 3 2512s but im still udecided on amp. im only doing this cause i know the only dd dealer in the area and he wants to see my roof flex like his maxima lol
DJTricky
Banned
Robbinsdale MN
i really have no problem with mine sliding around.....
but if you want to know how to fix it, you could do how i did it... bolt it through the floor (hole through the floor and then sealed up)
destroyer1362
A work in progress
Midlothian, TX
What if you just glue some of that spiky material like whats on the underside of the floor mats to the bottom of the box?
drowndindreams
Unknown
dont have a prob with mine, its too wide. put some double sided tape between the belly of the box and your floor of your cargo area. this way you dont have to get messy and bolt things down.
DJTricky
Banned
Robbinsdale MN
what that aimed at me? my box is far from messy. i bet there are 3 or 4 people with boxes on here that are "clean" or even show worthy. there is no way that my box is going any where with out unbolting and cutting it out...
with that said, im not gonna brag about having anything special, i just gave him an idea on how to keep his box from moving...
WH0DAMAN
A couple strips of Velcro should do the trick. Is your box carpeted?
drowndindreams
Unknown
as did I, that wasnt directed to you, it was for swab.
DJTricky
Banned
Robbinsdale MN
ok and my bad i was just a little on edge with having my amps and subs stolen and my t-case going out all in the same week....
TahoeGoBoom
blue interior guy
Build a bigger box. 48" wide cant move without making it.
or use the bolts. or be like me and do both. lmao
bass1775
Maryland
i use a bungie cord and the cargo hold downs. Works fine. May have to reposition the box.
1999hoe
aka HOVERHOE
Massachoochoosetts
doesnt budge
DJTricky
Banned
Robbinsdale MN
thats the kicker box with the huge like 6 or 7 inch port on the left side right? if so you might get better bass if its not so close to the amp
moto
