Hit the track today
tights24
There doesn't seem to be as much traffic here in this performance section as there is over on Titan Talk. Maybe this isn't the biggest Yukon forum though. Regardless, i hit the track today with my 2007 Yukon SLT. Ran a 15.9 bone stock. Semi disappointing, but I think it can be rectified. The shifting is really odd in this thing. I'm 99% sure I have the 4 speed. It's a slug off the line for sure only cutting a 2.54 60ft time. When first gear gets going though it runs pretty strong. Then the let down. From 1st to 2nd is atrocious. It almost seems like it misses a shift in a stick car. It's odd. it falls completely on its face during that transition too. I didn't pay attention to my rpm's, but it almost seemed like when it shifted my rpm's were just too low afterwards to stay in any kind of power band.
Now, don't get me wrong, I didn't buy this truck to go fast, and I knew what I was getting into in a way, especially since most american vehicles are overrated for HP and the Titan I came out of was underrated, but I sure would like to be able to beat a minivan.... I ran the same trap speed at 89mph that I did in my Titan and my Titan ran a 14.9 with hardly any mods.... Thoughts anyone?
I noticed the Hypertec programmer allows changing shift points and firmness. Will this cure this thing?
Intimidator3
I'd say that most people are going to recommend getting a tune from Black Bear Performance (check the vendor section). After they tuned my Tahoe, it was much more responsive and the shifts were much smoother. They should be a good start.
Jmat
Southern Cali
I know exactly what you're talking about. That 1st to 2nd shift was such a let down on my truck as well. A BB tune made for a huge improvement.
Big Buttons
The SS Burb
South Texas
But seriously a tune and stall will help a hell of a lot. You can still tow and daily with a conservative stall.
T
tights24
Thank guys. Yeah, it looks like Black Bear might be in my future. I was just trying to save a few bucks by buying a used handheld tuner. Usually you can cut your price in half this way and still get a decent performance bump out of it. $600 for a tune just isn't in the budget. I may just try a Hypertec and see what it does. I had the best success with their product on my Titan when comparing to Bully Dog and Superchips.
I'm just glad to see that I'm not the only one with the problem. This is my DD and I had enough "go fast" mods on the Titan to get that part out of my system. But I'll be damned if I let a non performance car beat me.... :)
Wakinvol
East TN
I wouldn't waste your $$...save for the BB and forget the Hypertech.
b4z
I'm actually surprised that a 5.3l rand a 15.9. The three cheapest things are a tune, stall and gears. )although some charge a lot for gears).
You are probably getting a ton of torque management on the 1-2 shift, timing being pulled back etc.
There is also a big gearing drop between 1st and 2nd. The 6spd is better in this regard but it has its own share of issues.
73shark
KC, MO
Torque management is the culprit. It's what makes it a dog off the line and at shift point. But it does allow for 5/100K powertrain warranty.
T
tights24
So will a handheld fix this or do I need Black bear? Sorry, not trying to be hardheaded and I do appreciate the help, but I find it hard to believe that a handheld tuner will do nothing and that Blackbear is it for tuning even a little bit. Like I said in a different post, with my Titan, we had Uprev which was the equivalent to EFI Live I guess. But, it really wasn't absolutely necessary unless you had headers or wanted to add a cam etc. With minor bolt-ons like CAI and exhaust, all the big handheld tuner companies were fine and they had pretty impressive results.
If my main problem is with torque management, is that all based in the TCM? Is Black bear my only option for getting into that if that's the case?
Oh, and thanks 73 and B4 and everyone else for the replies.
73shark
KC, MO
I believe that Blackbear can remove some or all of the torque mgmt and do lots of other stuff based upon what you want.
I don't know if any handheld tuners can do it but then they will cost as much or more than BB. At least you should check w/ him.
Look real close look at add-ons like CAIs, cat-back exhaust, etc and you'll see that most, if not all, the hp increase occurs at high rpm. Not much good for stop lite racing. ;)
T
tights24
Yeah, I could feel that and the track was a testament to that. My truck was a full second faster with minor boltons and it trapped the same as the Yukon. Plus I was pretty much the same weight. Titans are torque monsters. I'm a 42 year old veteran with a second kid almost here, so I just like to go fast when at the track, or in short bursts. Looks like I'm stuck with the track now. Hahaha. Thanks again.
T
tights24
Wow, I just got lambasted over on the Sierra/Silverado forum. I joined to find some more info about the 5.3 since it has a much bigger performance section than here, no offense. They came unglued because I tried to post questions asking about tunes and such for my Yukon. "This is a Siearra only forum, blah blah blah". Jesus, I'm just trying to get some different answers about their beloved engine. I understand their point in a way, but you'd think they'd be happy about a GM owner in general. It's not like I was going to be a post ***** there. Wow, that's all I can say.
Big Buttons
The SS Burb
South Texas
For performance talk I go to LS1truck.com. Over there they're going to recomend nelson performance for tunes.
MACHO
Seattle, WA
BlackBear will give you custom TCM tunes and you can request the amount of torque management. They've done mods for some members like Sumo's where they removed it almost entirely for a SPORT/track mode that can be engaged when pressing the tow-haul mode button. I had my '11 tuned via the AutoCal by them for Daily Driving and a performance 91+octane tune and absolutely love it!
JennaBear
Resident Ninja
San Diego, CA
Nelson is the owner of that forum :slap:
You are correct, all or none of the TM can be taken care of (and anything inbetween).
To the OP, Black Bear uses EFILive for all tuning on 98+ vehicles.
2007tahoe
I also went from a nissan titan to a 2007 tahoe. Very disappointing step down power wise. My titan also ran a 14.9 with little bolt-ons. Loved the titan in every aspect but the tahoe averages about 4 mpg better. I remember pulling a 2600 pound trailer with the titan and getting 9 mpg. I pull a 6000 pound trailer with the tahoe and get almost 12 mpg. I like my tahoe but if it wasn't for the kids I would have kept my titan!
brice715
