tx01tahoe
TX
So far I have restored my headlights, plastidipped my bowtie, taken that stupid antenna of the back side window, and taken off the dealership sticker on the back. Not sure why I choose to do these things on a rainy day.
tx01tahoe
TX
Getting a head unit installed and front windows tinted right now, woohoo!
Red_Raider
Derby, Kansas
Added a whole bunch of parts to my wish list on eBay. Wish the black bear event wasn't full in Sacramento or that would be one of my boxes checked :lol:
Pachanga02
Ny
Finally got my led bulbs for the puddle lights, reverse and interior dome lights. Interior is complete and exterior also with led bulbs. Only question I have is why does my rear camera come on when I press the brake no image just goes black. Rearview is connected to the reverse light but its only supposed to come on when its in reverse not every time I press the brake. Replaced led bulb with stock bulb and it was fine no interruption when pressing the brake. Anyone????
txsmainevent
"The Lurker"
Have you thought about doing white wheels? Like Blazed's NNBS? Your truck looks good though.
Fixed an oil leak from the dumb ass' at Midas tightening the oil filter too much. Replaced during oil change, good to go. BTW im overseas so i cant change my own oil.
tx01tahoe
TX
Dropped my gas tank to replace my fuel pump assembly and it sucked. Also replaced my rear window motors
Big_D
SLP, MN
moved it out of the drive way so my freebie sled trailer could be dropped off and then moved it back ha
Kman
Southern California
Bought 5 quarts of ATF, the filter kit, and other stuff to drop the trans pan to change the filter and fluid. Couldn't get the trans drain plug off. Used a blow torch and a 10 foot breaker bar. No luck. Ended rounding off the bolt. From what I've read online it's a common problem as GM over torqued the shit out of the drain plug.
I said screw it. Bought a new drain plug. Going to see if the local trans shop can get the drain plug loose this week.
Grebbler
Parts is parts...
Michigan
Today was a nice day and my front end parts were not delivered :(
So, I did oil change, chassis lube and replaced the original serpentine belt. 200k on it. It was stretched 1.5 inches, light wear and I only did it cuz it started squeaking.
Then I repaired headlight housing that I broke when leaning in to swap the belt.
Red_Raider
Derby, Kansas
Bought a gauge overlay. Now I'm looking to buy the cluster lights since I'll be in there anyways. Also I started looking at a 6" suspension lift instead of a drop. Buddy showed me a members truck lifted on 24s!
coolchuck
maybe Escalade bound?
DC Suburbs
Installed my Christmas gift...Pioneer AVH P1400
Monitors up next.
ALL4WD
I bought a new to me 2010 Denali to replace my 07. Arrives Tuesday... can't wait!
MrBalll
West Texas
Had this put in. CD player was going out in the original one and since there isn't an AUX in these Tahoes I was getting tired of the radio.
Pioneer AVH-X5500BHS
jdpber
GOLD MEMBER
The America
New belts.
Old belts I believe were the originals... They are marked GM lol 164k on original belts. That's cool
tahoeroy
Somerset, NJ
2002 Tahoe Z71.........215K & still going strong. Changed the water pump, thermostat, Belts, Upper & lower radiator hoses, rotated the tires and did the swiss cheese airbox mod. Now I'm going to go cruisin'
a4edwin
ny
how do you like it so far?
dragginwagon406
Washed, clay barred and waxed.
Reading up on it since we just bought it yesterday. 2004 6.0L, 175,000 miles. Need to find out about spark plugs; what works and the gap. Will AZ get this right if I stop in there?
Also having the HVAC issue with the dual zone climate control.
Drewphil
