Rear Main Oil Leak? *pics
j.wes
Hi I have been using this site for information for a while, love it, but I need some help now. I have a pretty bad oil leak, I am losing 1/2 quart about every 2 weeks or so give or take. I have posted some pics so maybe someone can tell if it is rear main as I can get a buddy to fix it for free and some moonshine for payment ;).
I have castrol gtx high mileage in right now but will be switching after I seafoam today to AMSoil 10w-30.
NBS 2000 Chevy Tahoe LT 4x4
5.3L
228,000 miles
I dont think its oil pan gasket as the oil pan looks pretty clean..
most of the pics show the point wear the engine and trans meet.
hope that gives you a good look.
Tommy 874
Looks like rear main leaking. You would have to pull out the tranny to fix it.
Kman
Southern California
My Tahoe looked exactly like yours when my oil pan was leaking.
In the first pic you posted, see the circle cover on the bell housing? Pop that off with a little blade screwdriver. Take a flashlight and look into the hole at the flywheel gear. If oil is on the gear from the center splashed out its the rear main If oil is just on the outside of the gear it's probably not the rear main.
Best of luck!
J
j.wes
thanks for the help, I cleaned the engine and I am gonna add some dye to be 100% sure
saltygq
Chicago
Were you about to find out where the leak was coming from. The wifes truck started leaking and your pictures look the same. No oil inside the bell housing cover. So I'm thinking(hoping) it's just the pan. Let me know what yours ended up being. Thanks,
NC_John
North Carolina
Best of luck!
My flywheel looked completely dry when my rear main was leaking. If he thinks it might be the oil pan, its a far easier job than the main and might be worth a try first (as long as the truck is a 2WD anyway)
Durobans
