Is my front axle about to fail? See pics.
pittmanb8
A little background- about 3 months ago I bought a 2004 Yukon Denali XL with about 34k miles. I was doing some fluid changes today and the below came out of my front axle drain plug. I have also included a pic of the clean drain plug. Does this look like normal wear and tear or is my axle about to have serious problems? I have not had any problems but want to know if something is coming my way. Thanks for your help.
WoldD90
Off Road Addict
Atlanta, GA
This is fairly common across most brands... That is why they provide a magnet on the plug.
unixadm
That's quite a bit of metal. If the diff is still quiet, do a service on it with fresh fluid. Change the fluid again 5k miles later and see how it is. I had my Yukon at the dealer a few days ago. The diff tech said I was on borrowed time and I had less metal than that. He said they fail quite often. Estimate of $1,000 to rebuild at the dealer. I did a full service on the diff when I got home and it has 142k on it - no noise yet. Knock on wood. That seems like an excessive amount of metal for a low mile vehicle. The tech told me, he's seem them fail with 10k and encouraged me not to buy a used one cause you never know with these aluminum diffs.
NathanJax
Vacation Nathan
Jax, Fl
Good info. This is what I've been reading as well...
unixadm
Aluminum does not stick to magnets.
Yes, I know that. However the differential casing is made of aluminum, which is not the best material for a differential case. The metal IS coming from the bearings and gear set, but some believe the actual aluminum casing contributes to the failure of these differentials. Plus these do not decouple fully meaning the internals are rotating at all times even on non-AWD models.
yooformula
Milwaukee, Wi.
damm thats what mine looked like today! I plan on servicing the diff again at next oil change, it's too easy not to.
gtbigup01
Columbus, GA
Man makes me want to go check mine, and I just paid $331 to do a 75K mile service, I'm sure differ fluid change was not inclided. I'll have to go check
Nope just regular oil change and the rest of other stuff
At my request:
1.Tranny flush + service
2. BG Fuel injection service w/filter change
Max
Mile High
Denver
Mine wasn't that bad but it was close. I swapped to royal purple and it's been fine since. I'm checking it again before my warranty expires but it stopped whining after I swapped to synthetic fluids...better mileage too.
gtbigup01
Columbus, GA
Ok somebody help me out with fluid weight. Dealer said about $70 each to service ummm think I'll do it myself and put some good stuff in there since it's not required to be done that often
axekick
Austin, TX
I can't see the pictures, I think they have my computer set to not show them at work. However, I've built differentials before. Don't worry about the metal. Just clean it out and don't worry about it. It's normal break in wear, especially if they're turning all the time. I bet if you clean out the metal and change the fluid and check it again later it won't have nearly as much metal.
I would never pay what they want to service or rebuild a differential. You could buy all the parts needed and all the tools needed to do both diffs in a 4wd for the price they want to rebuild one of them. I could rebuild one in a weekend easily. After the first one, the second one would be easier and could be done in one day.
D Rollins
