Hydro-Boost conversion
DIAZ
So I finally upgraded my brakes to hydro boost on Saturday and I have to say best coversion ever and its night and day with my brakes. Didn't require too many parts and only 1 modification had to be done. First off I like to say I have a 95 Yukon so I don't know what would be the difference from the 96 and up would be. I got the hydro boost off a 1998 Chevrolet 3500 with a 7.4. I initially took the power steering pump all the lines, of course the hydro boost, the master cylinder and the brake pedal. I bought new lines becuase when I took the other ones off it looked like they were leaking oil and since I didn't want to do the work twice I just bought them new. All together I spent about $100.00 thats parts and all. The Hydro boost was a direct bolt on to where the power booster was at and from what I saw the master cylinder was exactly the same. I've also read that the brake pedal would need to be changed but when I compared both mine and the one off the 3500 it was exactly the same so I didnt need that. Also you have to change the power steering pump since the pump has 2 returns and 1 pressure. All together the system has 4 lines, 2 pressure hoses and 2 return hoses. One presure goes to the Power steering to hydro boost and the other presure goes to hydro boost to gear box and same with the return. The only modification that had to be done was to the metal bracket that connects the power steering pump and alternator, which is behind the power steering pump had to be cut in half. It took about 3 hours to do all the work and only because it was raining so had to stop a few times. If you want more pictures let me know.
NathanJax
Vacation Nathan
Jax, Fl
looks good!
(moved to Engine & Drivetrain section)
NathanJax
Vacation Nathan
Jax, Fl
Thanks and sorry about that.
no worries. New area in the last few days. Don't think many people even know... lol
DIAZ
DIAZ
No i don't, didn't think about it till after I was done.
96ProCompTahoe
IN
ive been wanting to do this for quite a while now, glad to hear of another member getting it swapped without any problems.
mudslinger96
Nice install bro. Been hearing alot about hydra-boost but haven't found any answers. What are the benefits? How hard is it to install? And where can i get the parts for the conversion?
DIAZ
DIAZ
Benefit wise, my yukon breaks 1000 times better, you will feel the difference in stoping power. The hardest part to do was swap the power steering pump and thats becuase of the pulley, other than that its pretty simple. Didn't run into any problems converting it to hydro-boost. It bolts right up to where the power booster was at and just run the lines to the power steering and gear box and bleed the brakes. For finding the parts you would need to look around to your local u pull it, thats where I found mine at. All you need is the power steering, all three lines that come with the hydro-boost, hydro boost itself. Master cylinder is the same and so is the brake pedal. That way you don't have to spend money on parts that you don't need. Mine hydro-boost came off a 98 Chevrolet 3500 with a 7.4. You can't really tell from the pictures but if you look at it you wouldn't be able to tell that it was a conversion.
NetBSD
was just talking about doing this swap last night with my cousin. i have a 92 c2500 with the 6.2L and hydroboost, never had a problem with them and the stopping power is amazing.
DIAZ
DIAZ
Here are a few more pictures of the setup. Sorry abou the pics, I used my phone and I don't know the lines are soo bright like that.
HOEIN
Rhode Island
I think I will be doing this, do you have any pictures of the modified bracket for the pump?
HOEIN
Rhode Island
So I converted mine over Christmas. Here are a few pointers you need to consider. Mine is 1999 Tahoe 4 dr.
Pedal
- you can use the stock one but you need to swap out the backing plate on the hyrdroboost with one that is centered (the one that comes with the hyrdroboost is offset to the bottom) There is a guy on ebay who sells them for cheap ($25) on ebay for an astrovan conversion, it is the same plate here it is http://www.ebay.com/itm/300797723373?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Steering Solonoid
- you don't need to use the variable steering sensor on the back of the pump (if you change to a hydroboost pump like I did) simply screw the pressure line directly into the back of the pump, you might need to "massage" the lines a bit to get it to route nicely, mine has a few of the stoc bends relieved so it clears the exhaust manifolds nicely, I didn't want my exhaust to heat up the fluid on the way to booster.
Brake switch retainer and pushrod
- You will need a new brake switch retainer as it's basically impossible to take the stock one off without destroying it. 1999 is different than the other years I think, you can get the retainers at advanced autoparts it is made by dorman I think it is like 5 bucks.
Master cylinder
- You need to match your master cyclinder to the hydroboost unit. Depending on the year and model the bore diameter of the hydroboost and the diameter of the protrusion on the master are different sizes. I ended up haveing to buy a new master cylinder from a C3500 1998 to match my hydroboost unit. Not a big deal but keep this in mind.
Hydroboost Pushrod, Retainer and Spring
- Finally, if you buy all new stuff like I did and you didn't get this stuff from the junk yard then you will find out that your stock pushrod (the rod that goes between the booster and the master) is too short and missing some parts. YOU MUST HAVE THE PUSHROD, SPRING and RETAINER assembly from a hydroboosted truck. Now I was lucky and hit the junkyard and pulled one and made it out for $5 bucks after some grumbling from the owner about it being part of the booster, some others might not be so lucky. Best advice is to plan on buying an old junk yard hydroboost with the spring, retainer and pushrod and swapping it out for a new one at the local autoparts store. Make sure you take out the old retainer and pushrod assembly before you do this because the reman units don't come with it!
Fluid
- Power Steering Cooler: my truck didn't have one and I didn't put one it. I did use lucas synthetic fluid and completely swapped out all the fluid when doing this (new pump, hydroboost and lines made this easy, I'm sure not much was left in the steering gear) I haven't noticed any issues with hot fluid but then again it is winter here in RI so I'll see how it is in the summer and may end up adding one.
Hydroboost to pedal pushrod
- Brake pedal booster pushrod: was fine I didn't need to modify this like others have said they had to, all you have to do is swap the booster backing plate to center it and it matches up in line with the stock pedal.
Impressions: Huge difference in brake feel, clamping force and stopping power! I heard this was a worth while upgrade but I never thought it would be this good. I Can haul this truck down from 60 mph and lock up the tires if I feel like it without much effort. And I have stock brakes, rubber lines and autozone duralast brake pads and shoes.
Again I did this on a 1999 Chevrolet Tahoe 4 Dr and everything I used was from a 1998 C3500 pickup with hydroboost!
Ken
Geo's66
Great advice, I have a 96 2dr tahoe I want to do this to... Question(stupid, I know), did you guys make new brake lines or did those come off the trucks at junk yard? I've never bent new lines so that's intimidating for a newbie.. What diameter lines and how did you do this? How difficult was it if you did your own? Thanks a lot
briannorris
