07 Tahoe, What Drop For 26s?????
wht06shee
Got a 07 Hoe and going to put 26s on it, and also wanna drop it as well.
offset on rims are +30 and i wanna say there 26x9
im not sure on tire size yet either......
its my wifes DD and she wants rims for her Bday (in a few weeks) and so im gunna buy her rims here soon, and also wanna drop it to
so my question is how much of a drop, and what all to get and from who
thanks
NORCAL SS
SUV SUSPENSION GURU
here you go
http://www.tbssowners.com/store/index.php?act=viewProd&productId=144
this way you start frest and front is adjustable from 0-2 inches in rear 3-4 inches. Only thing on the 26s i would do 1.5 in front and rear kit as the above kit shows and add another set of 1 inch spacers which would add $40 dollars. Also with the above kit you start with new shocks all around and a nice ride.
any other questions just hollar ive done a few already
tire size to go with is 295 30 26
CHOO CHOO
BackPagePhil
Manheim, Pa
+1 ^
I have a 2/4 drop set up from tony. Top notch stuff and best customer service i've ever seen. You can't go wrong with what he recommends.
wht06shee
wht06shee
here you go
Pm'ed You
+1 ^
Thanks
Zlub21
Does everything bolt right up or is there rubbing?
NORCAL SS
SUV SUSPENSION GURU
Bolts up and rubbing isi fixed by trimming plastic in wells no biggie
Zlub21
Thanks for the response NORCAL SS, do you reccomended only using a 26x9 or will a 26x9.5 or 26x10 work?
Jagger12
I have 2" front lowering spindles, Belltech struts with another 1" drop and 4" lowering springs in the rear. I run KMC slides 26x10 with 295/25/26 with no rub at all. I will probably go to a 295/30/26 next time.
baggedlvintegra
Fort Worth, TX
Just finished dropping my Escalade on 26's...26x10 Forgiato's ~30 offset (custom 3 pc, dont release offset) with 305/30/26 with Belltech 2/3-4 kit for autoride. Here is the stance on mine with the rear spacers in (about a 3.5" drop I think)
No rear rubbing but some good front rubbing that I havent gotten completely rid of yet. You are limited with modding the liners in the front due to the windshield wiper resevoir and the mounts on the back side closest to the door.
As a side note, IDK about your girl but I would NEVER put 26s w/ 30 series tire on any women driven vehicle, the rims will be square in no time! Just my .02
Zlub21
How smooth is the ride lowered on 26's? Can you still tow with this setup or no? Not super heavy towing but a single axle trailer.
NORCAL SS
SUV SUSPENSION GURU
it rides nice honeslty. Also if you tow you can add helper bags in rear.
Jagger12
I tow a 21ft boat 3 times a week with mine. I do have helper bags in the rear.
wht06shee
wht06shee
I actually just installed 24s, was Gunna do 26s but its for the wife and I felt better with 24s, also I'm Gunna lower it still
Blazed
Accepting Donations
Less chance to bend rims as well.
Zlub21
what kind of mpg's are people seeing being lowered on 26's? or even on 24's?
Blazed
Accepting Donations
Lowering doesn't really affect mileage and you can't really judge how much your MPGs will change because of rim size because everyone drives so differently.
Zlub21
Well lowering it should reduce the drag am I wrong? And I was asking what people were getting for personal numbers just so I can get a rough idea.
Drewphil
