Rear Door Not Opening
Travieso
Boooooooost !
Los Skandeles, CA
Anyone ever experience this ? My rear hatch Wont open at all not even the rear glass.. How to go about fixing this im thinking the Motor is out ?
GangstaCowboy
I had the same problem. Motor is bad and there is no key hole to unlock the door manually. If you search ebay there is a guy selling these randomly for like 60 bucks. Otherwise it is 300 at the dealer.
Travieso
Travieso
Boooooooost !
Los Skandeles, CA
can you provide me with a link and what are the steps to getting this door unlock/opened ?Thanks
GangstaCowboy
On my 2006 the rear hatch/door has no key hole or exterior way to unlock/lock the door if the motor inside fails. There is the handle at the bottom and the hatch button but when the motor fails the door will not unlock or lock depending on when it failed. I have seen other Tahoe's with a key hole in the hatch button but mine does not have one. You can remove the interior panel of the door to get at the motor. The plastic can be fragile so be careful. Here is the link to the motor I purchased. I guess I should say actuator instead of motor here.
http://www.ebay.com/itm/Yukon-Subur...:2006|Model:Tahoe&hash=item3ccc0dd346&vxp=mtr
gilbo
super easy fix, i just fixed my suburban about a month ago, got the part ebay
ill post the link when i get home, big brother has it blocked here at work
like 30 min max to repair
the link that GangstaCowboy posted , is the xact piece that needs to b changed
bacano_2006
Can you guys tell me how you got the old actuator off. I got the one off ebay and have been trying to install it but I can't get the old one off.
Travieso
Travieso
Boooooooost !
Los Skandeles, CA
well guys i finally fixed the actuator, and it was a easy instal, i replaced the whole mechanism. Glad to report the the rear hatch is finally functional now
vsaravia
