ABS and E-Brake Lights
Red_Raider
Derby, Kansas
Ok so last night I was driving around town doing some errands. After one of my stops, I proceeded to the next one, but my ABS and E-Brake lights came on! I checked the parking brake just to make sure it wasn't engaged and it wasn't. I made another spot and the lights went off this time. I'm not sure what could be causing this problem. Any ideas?
Gzes
the drifting 2dr
Wichita tx
Dirty sensor or bad sensor. If its not a problem then pop out the light;) jk but yea check the sensors
Red_Raider
Red_Raider
Derby, Kansas
Ok so I went to Auto Zone this afternoon. They pulled a P0032 code. It has nothing to do with the abs or parking brake. Instead it is a knock sensor. Anyone help me with that?
PwtrSS_OakCliff
Dallas, TX
That does not make any sense. Why would the brake and abs light come on with a knock sensor. I have the same problem. As stupid as it may sound, it was raining when I did it but I drove about 40mph and slammed on my brakes (in an empty parking lot) and the wheels locked up on me. Its the abs module located between the driver seat and the passanger under the truck. Known GM problem. Some say just to take out the ground and clean it from rust and re ground it, but I did it and its still there. ABS does NOT work!!
Antonio
Donnie Yukonie
Yates Caretaker
Well Unless your CEL light is burnt out that could be the case as for the ABS issue are your brakes acting funny?
check your hubs sometimes a bad hub will trigger a ABS issue
Z-56 Hoe
What do I do????
Houston
Check front wheel speed sensor! The abs and wheel speed sensors on our gmt800s are known to have issues.
Red_Raider
Red_Raider
Derby, Kansas
Will do I have to look at my knock sensor too while I am at it. I guess a "great" weekend project I have for myself :lol:
Z-56 Hoe
What do I do????
Houston
Hey at least you can go to the auto craft shop. Since I ETSed I have my driveway.
doylee4693
Tahoe User
New York
I hear the speed sensor should just be cleaned and reused but I cant figure out why people dont just buy a new dorman sensor.I wonder if the dorman sensor has the same issues as the sensors on our trucks.My sensors have been cleaned a few times already and my truck only has 65,000miles.
briannorris
