My install - Pioneer DD & Headrest & iPad
NathanJax
NathanJax
Vacation Nathan
Jax, Fl
thats the exact same HU i have. did you see any type of way to use the factory buletooth mic instead of running the poineer one. I like the way the factory bluetooh is setup and want to retain the way it operates.
no idea as I didn't have factory bluetooth. I'm guessing no though, because factory bluetooth goes through onstar, so i'm almost positive you can't
chevyboy23
JUST QUE DOGGING!!!!
South Florida
oh.......well the search continues. I think I can keep it if I just dont hook up the bluetooth on the pioneer
aflumb
Las Vegas
I know this tread is a ill old but Nathan how did you get ur screen to show ur ipad. The reason I ask is I have a Pioneer Fb900 and I'm trying to get my Ipad 3 videos to work. I am using the iPod wiring connector. I have the videos from the iPod working just not the ipad
NathanJax
NathanJax
Vacation Nathan
Jax, Fl
I'll have to try it on my brothers radio to remember. I think there's a button on the right side you hit to go from audio/music to video input
chevyboy23
South Florida
After you did your install. Did your USB port in the console still work. And do I need the gmos LAN 02 OR the gmos LAN 012. Thanks in advance!!!!
NathanJax
NathanJax
Vacation Nathan
Jax, Fl
I never had the USB in the console, and I used the GM LAN 012
aflumb
Las Vegas
Yes u will lose it. I don't think any of the adapters have it included in the wiring
chevyboy23
South Florida
Put in my radio today. Sounds MUCH better than the factory. Even turned the signal up on the Gmos LAN 02 so now I bose system sounds a lot clearer. Was thinking about tearing the Bose stuff out but changed my mind. Next thing is the chameleon monitors and a set of subs. Then I am done.....as far as the audio goes.
aflumb
Las Vegas
Nathan would u happen to know the wiring u used to go from ur ipad to ur head unit
NathanJax
NathanJax
Vacation Nathan
Jax, Fl
I used the Pioneer iPod cable. for the 8400 i have the CD-IU201S and for the 4400 i used the CD-IU201V
aflumb
Las Vegas
Ok kook. The reason I ask is I have the Pioneer cable that I use for the IPod. But when I hook it to my Ipad it will play for a sec then the Ipad say acc. Not req.
NathanJax
NathanJax
Vacation Nathan
Jax, Fl
hmmm... never had that happen.
aflumb
Las Vegas
Yea. I think I'm just gonna order the Apple AV cable so I don't have to worry about it being wrong. Also when u installed ur head rest where did u get your ign power source from? Sorry for all the questions. Just wanna make sure I do my stuff right. Again thanks for all the help
NathanJax
NathanJax
Vacation Nathan
Jax, Fl
From the same harness as the radio. Just ran a couple wires back there. since I ran the headrest to/from the radio. My headrest can play their own thing, or they can play from the output of the radio.
:Handshake:
shundal
NorCal
:Handshake:
Did you tap into the remote turn on lead of the Deck for the power? I need to wire my istreamer to a switched cigarette lighter and wanted to use remote turn on from the deck to power the istreamer. Do you think there is a need for a relay if running multiple amps and an accessory off the remote turn on? I know there is switched power near the drivers side kickpanel, but it would make it much easier to just go off the radio.
NathanJax
NathanJax
Vacation Nathan
Jax, Fl
If running multiple accessories, I would run a relay.
shundal
NorCal
Thanks. I ordered a relay yesterday just in case. Right now I'm running 2 amps off the remote turn on. The istreamer will be the only accessory i'm running, but it's probably better to be on the safe side.
Yizzo88
