Second Row Bucket Seat has a Broken Armrest
mattjones
VA
So somehow one of my second row seats got a broken armrest the weekend before last. I think the seat was folded and tumbled forward when the arm was damaged. It's like it hangs a little looser than it should. It goes a little bit out from the chair and hangs lower than it should. Any idea how to fix it? It almost seems like a screw needs to be tightened somewhere that it connects to the seat.
Here's a picture, I'll try to take more if you guys want me to:
Jdenton13
That round cap on the armrest pops off and you can take it off from there. I don't remember if its a bolt or nut. I've never taken one off but there might be a stop or something in there that it popped past. Hope this helps.
Sent from my DROID RAZR using Tapatalk 2
DMOGIRL
same thing happened to mine. thankfully it is still under warranty and they fixed it. i blamed it on my kids jumping on the arms. :(
mattjones
mattjones
VA
Mines broken like yours...
p.s. this pic is HUGE.
Anyone have any advice for an '02?
Sorry. I took a few more that are clearer and hopefully not quite as large. It looks like I just need to tighten a nut, but I need to figure out how to get a socket wrench in there. Hopefully I can reach it with an extender.
Also, don't pay attention to the loose stitching on there.
floggump
Did you ever get a fix for the armrests? Same issue on mine, and I know it's common, with others having the same issue. Dealer fix is not an option.
mattjones
mattjones
VA
Yeah, sorry for not posting a follow-up earlier. I basically just had to tighten that bolt inside the armrest and that took care of it for the most part. I needed one of these in order to reach it:
At the time I had no idea what size I needed, but the people at Advance were nice enough to let me take sockets out to my truck in order to figure out which one was the right size before I bought it.
Bullitt3055
Avoid lowering and raising the armrest after it's been repaired and everything will be fine.
garymyman
Louisiana
Mine has the same problem. But tightening the bolt does nothing. It feels like the piece inside the chair's upright portion is loose.
I take it there's no easy fix, besides taking it to an upholster shop or, worse, the dealership?
raress9596
Long Island NY/ Boynton Beach Fl.
I have an even dumber problem. The plastic cap broke off on my armrest. I found it lying on the floor. I want to buy a new one but can't find a part #. It's under warranty but it means two trips to the dealer which I don't have time for. I'd rather replace it myself.
M_Kingston
I have the same problem with mine...any help on the part number would be great.
Thanks
raress9596
raress9596
Part number is...15279689
Dealer had one in stock which is amazing! Told me this is a common issue and they keep one in stock at all times. $6.12. I paid for it though it's unde warranty. My time is too precious to have to make an appointment fo service. Parts guy told me to contact G.M. To get reimbursed. Can you imagine, lol!
Ronald3938
2007 GMC Yukon Denali
Did any of you guys ever figure out how to remove and/or repair your 2nd row armrest. I have the same issue with mine but cant find any information on how to remove it. I tried sticking my arm up inside the back of the seat but couldnt feel anything. Everybody says this is a common issue but I cant find any info on a fix for it. Mine is just hanging by the bolt and I cant remove or tighten the bolt. Someone please help.
GM Customer Service
Michigan
Ronald3938,
Hello! I am sorry to learn that you are experiencing an issue with your vehicle regarding the 2nd row armrest. I might be able to give you any technical advice but I would like to look into this concern for you. Please private message me if I can be of any assistance.
Regards,
Jennifer T.
GM Customer Care
jack oderland
Have the same problem with mine Escalade 2011 ESV :/ Armrest pointing at the floor all the time....
I have ordered the plastic cap but need some advice on tool to use to tighten up the armrest if possible.
Living in Sweden and the only dealer here says a new chair is needed lol?!
DeanJ
The shaft is a 5mm hex, use a 1/4 drive 5mm socket on a extension shaft through a 13mm deep 3/8 drive socket. Hold the 13mm deep socket with a visegrip while counter clock wise on the 1/4 shaft 5mm socket. This will tighten the nut on the shaft. Other wise the shaft spins when turning the 13mm nut.
denalianyone
NYBlackLade08
New York
13mm deep socket is what worked to tighten mines. No vice grip was needed.
langsbr
Does anyone know what, if available, the part number is for the the armrest stud? It appears that possibly in 2011, they changed from a stud to a bolt, and notes say that the stud may need to be removed. Mine is cross threaded, and I cannot get the nut to tighten enough. I was able to get the stud out, but I can't find a part number for it, or the replacement bolt.
The Whip
