play in steering need help
Donnie Yukonie
Yates Caretaker
i thought that was an issue with the nbs only? i mean of course over time they will but i thought i read somewhere the nbs models had them wear out prematurely causeing a pop in the steering column ... could be wrong tho
Z
Zack757
turns out ive just got a worn gearbox. all steering linkages are good and the steering collumn u joint or rag joint has no obvious wear or tear. i can see the steering collumn turn before the pitman arm starts to move. I geuss 220 thousand miles will do that lol XD
nate3531
bootheel
My 97 has a badly worn rag joint that I want to replace with a u-joint. Soon as I figure out how I will. I know on Pre-95 maybe 96 you can swap in a jeep steering shaft from an xj. Works great, I done in on an 89 I had. Loved it. Hope I can figure out how to do it on my 97.
WilliamRWetzel
Idler Arm and Bracket. Pitman Arm. Tahoe Boxes Always Seem To Have A Little Bit Of Play In Them.
ralatkkins
I hope you figure this out......
because i am having the same issue! I have new everything underneath the truck except the steering box. Plus i have a question, does the 95's have the steering motion sensor?? i am finding conflicting reports on it
rolfsent
Cincinnati
1997 got the evo sensor.
BlazinMilk
