Shutting off at 80mph
NORCAL SS
SUV SUSPENSION GURU
Well after having out truck for over 7 months finally decided to see what all gears go up to. Up to now the most ive gone is prob 75 on the freeway my wife usually drives our escalade.
Get this i floor it and 1-2 pulls fine get into 3rd hit 80 mph and truck goes into limp mode hits 79 mph you can hear it hit the gas again. I need to pull the tune out of the truck tomorrow and see what it says but I dont know why gm put a 80mph limiter on my truck.
Donnie Yukonie
Yates Caretaker
80 limiter? doubt it most are at least 90 95 even my yukon i could hit the needle stops after 100. but you said A tune?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
truck has never been tuned. Im pulling the stock gm tune hopefully tomorrow and see whats going on because its only at 80mph goes dead. Ive never heard of this so kinda like wtf?
quattrotman
I think it's actually limited at 105mph from the factory. Might be something else going on there. 80 is too low for a limiter.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
yup happens at 80mph only like dead no fuel. Truck goes to 75mph you hit it drops down and pulls good then 80 hits and boom dead. Ill figure it out tomorrow because I can't see anything else that is going on.
stevek
Dallas, TX
After using 5 different NNBS (Tahoe, Tahoe, Yukon, Denali and Denali) they definitely weren't capped at 80, but near 100. I know my Denali gets to a little over 100mph in 3rd if I remember correctly.
LuSe4
Bleen Member
Michigan
Just get a bumper sticker that says "Built for looks, not speed!".
Curious to find out What is wrong.
Gzes
the drifting 2dr
Wichita tx
Tony i dont think its the limiter. We used to race trucks down the highway and got them to 105 no problem. Plug the computer in and see whats happenening because yea it should atleast hit 95-100
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
yeah ive been racking my brains out all night (its 552 am here now lol)
I know it cant be a engine issue because the ****** does pull hard out the hole (my buddys silverado runs 14.40s and he drove it said it feels like his up to 80)
Coming back from sf last night i ended up trying to go past 80 under light throttle and boom same thing stops at 80 oh well ill know in a few hours whats up.
soulsea
Bar
Oh thank god for that.
The solution seems simple enough ... just duplicate all the CTS-V performance mods onto the Escalade = problem solved. :)
Seriously though, it's very strange that the only symptom is an 80mph limit ... hopefully a simple re-flash can return it back to the way it's supposed to be.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
i pulled the rear autoride shock connectors so i have a service suspension system sign (i need to wire in the resisotor just cant find the correct female plug) and so the truck turns off at 80mph. gms own safety governor
soulsea
Bar
Oh that's good to know ... and it seems an easy fix.
I should pull my links out just to keep myself from speeding. :)
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
its off the top of the shocks that affect valving of the shock. The compressor still works and fills up the air in the shocsk wheni load it down.
Buford bubba
