oil fill tube question
Tbruz
Windham NH
1997 5.7 Tahoe.
I have a leak under/in the oil fill tube where it inserts into the valve cover.
GM part is 12551357 for around $40.
Can't seem to figure out how to remove it to check for a crack down low or a bad gasket.
Does this even have a gasket/o-ring between tube and valve cover?
Any inputs appreciated.
Thanks
Tbruz
SunlitComet
OBS Jedi-Do Good
unknown at this time.
yes on the o-ring. it has probably has just shrunk over time. it happens. iirc get a good grip on it and yank that sob straight.
---------- Post added at 04:38 PM ---------- Previous post was at 04:37 PM ----------
btw o-ring should be included in tube kit.
---------- Post added at 04:39 PM ---------- Previous post was at 04:38 PM ----------
try unscrewing first just to be sure.
T
Tbruz
Windham NH
Sunlit thanks,
Twisting/unscrewing did not work nor did pulling on it.
Any chance its nutted from inside the valve cover?
Tbruz
SunlitComet
OBS Jedi-Do Good
possible but i don't see a nut in the parts diagram below nor is there a part number for one. regardless you know the ring comes in the tube and is not available separately so you know you have to order it. so i suggest doing so and inspect it when you get it and even post some pics of new, old and job here. sorry i could not do more.
http://www.genmotorinfo.com/Picture.../5.0M,L31/5.7R)+-+TC00-131&pid=060426TC00-131
gpracer1
Phoenix
From what I remember from when I did my rockers, it unscrews.......need Kung fu grip.
T
Tbruz
Windham NH
I got it to turn about a quarter turn but no joy in removing it.
Going to order one this week and will figure out how to remove the old one once I have the replacement in hand.
Adamsusa
1997 5.7 Tahoe.
Thanks
Tbruz
Tbruz have the same question. What did you find out? Does it unscrew maybe with lots of force??
03catburban
Georgia
It unscrews but it's probably gunked up and I dont remember if the obs ones go a quarter turn or full screw lol
Candielaine
